2017-06-18 - Kernels, Plasma, KDE Apps, Firefox, Thunderbird, Mesa (Stable Updat
Hatte keine Probleme.
3
75%
0
Keine Stimmen
1
25%
Insgesamt abgegebene Stimmen: 4
Hi community,
for our KDE-Lovers we have updated KDE Apps to v17.04.2, Plasma to v5.10.2 and Frameworks to v5.35. Also QT got updated to v5.9, which resulted in a rebuild of other packages.
We are also happy to present the latest Mozilla software to you. Firefox is now at v54.0. Thunderbird on the other hand is now at v52.2.
Also this update brings a huge rebuild of perl packages. Please check if you have installed some packages from the AUR which depending on an older release of perl and remove them before updating.
Other things to mention with this update-pack:
We finally found some way to fix the Calamares crashes on some partition types. Thx flies also out to Andrius and Adriaan from KDE for fixing this long lasted bug. You may review the changelog.
Fabian filled the upstream bug for Octopi crashing with QT 5.9, as we thought. In the end it was no theme issue at all, rather some compiler oops with gcc7 and the alpm-backend after Marcus gave us the clue where to look. Solution was to use clang as compiler to get all going.
Philip released again Greg's kernels as usual. This time almost all extramodules needed to be compiled due abi-changes.
The glibc/mkinitcpio-busybox-issue should be fixed now on i686. Please report if otherwise.
Last but not least Frede finally released pacman-mirrors v4.2.
As usual you find the regular upstream packages, such as eric, haskell and python. Please give us feedback and report any issues you may see with this update.
Current supported Kernels
linux310 3.10.106
linux312 3.12.74 [EOL]
linux316 3.16.44
linux318 3.18.57 [EOL]
linux41 4.1.41
linux44 4.4.73
linux48 4.8.17 [EOL]
linux49 4.9.33
linux410 4.10.17 [EOL]
linux411 4.11.6
linux-RT-LTS 4.4.70_rt83 (x86_64)
linux-RT 4.9.30_rt21 (x86_64)
Package Updates (Sun Jun 18 22:19:51 CEST 2017)
stable community i686: 1201 new and 1102 removed package(s)
stable community x86_64: 1235 new and 1135 removed package(s)
stable core i686: 44 new and 49 removed package(s)
stable core x86_64: 44 new and 48 removed package(s)
stable extra i686: 1044 new and 1098 removed package(s)
stable extra x86_64: 1044 new and 1099 removed package(s)
stable multilib x86_64: 22 new and 29 removed package(s)
A detailed list of package changes can be reviewed here.
Re: 2017-06-18 - Kernels, Plasma, KDE Apps, Firefox, Thunderbird, Mesa (Stable Updat
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.11.6-1-MANJARO x86_64 (64 bit)
           Desktop: Xfce 4.12.3 Distro: Manjaro Linux
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
Guayadeque startet nicht. Folgende Meldung:
guayadeque: error while loading shared libraries: libwxcode_gtk2u_wxsqlite3-3.0.so.0: cannot open shared object file: No such file or directory
Bisher noch keine Lösung gefunden.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
m-bostaurus
Kernel: 510
Has thanked: 51 times
Been thanked: 12 times
Beitrag von m-bostaurus »
Bei mir lief auf allen Rechnern das Update durch.
@linuxkumpel: Ich habe einen Vorschlag ins Blaue, was ich selber mache, wenn ich die Meldung erhalte, eine Datei sei nicht da. Ich lege eine leere mit der Bezeichnung an. Hat schon geholfen. Ohne jede Garantie.
linuxkumpel
Kernel: 5.15 / 6.0
Bezüglich Guayadeque - Lösungsansatz
https://forum.manjaro.org/t/stable-update-2017-06-18-kernels-plasma-kde-apps-firefox-thunderbird-mesa/26086/106?u=linuxkumpel
sudo pacman -U http://repo.manjaro.org.uk/pool/overlay/guayadeque-0.4.5-2-$(uname -m).pkg.tar.xz
linuxkumpel
Kernel: 5.15 / 6.0
philm hat noch einmal nachgelegt.
sudo pacman -U http://repo.manjaro.org.uk/pool/overlay/guayadeque-0.4.5-2.1-$(uname -m).pkg.tar.xz
https://forum.manjaro.org/t/stable-update-2017-06-18-kernels-plasma-kde-apps-firefox-thunderbird-mesa/26086/112
Jetzt klappt es.  ???
