2017-06-11 - QT v5.9, Perl Rebuild, KDE Apps v17.04.2, Deepin (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
this update-pack is a little larger than our usual updates. We have updated KDE Apps to v17.04.2. We had a QT v5.9 rebuild and updated Wine, our RT-Kernels, plus renewed nvidia-340xx driver.
Also this update brings a huge rebuild of perl packages. This might bring some instability or issues to current perl packages, since we didn't found the time yet to check what might be broken on our end. This you can do yourself on your local installation with the provided script. You may need also one pl-module to get the script working.
Other than that you may find the regular upstream updates as usual. Please give us feedback as usual and report any issues you may see with this update.
Current supported Kernels
linux310 3.10.105
linux312 3.12.74 [EOL]
linux316 3.16.44
linux318 3.18.56 [EOL]
linux41 4.1.40
linux44 4.4.71
linux48 4.8.17 [EOL]
linux49 4.9.31
linux410 4.10.17 [EOL]
linux411 4.11.4
linux-RT-LTS 4.4.70_rt83 (x86_64)
linux-RT 4.9.30_rt21 (x86_64)
Package Updates (Sun Jun 11 08:13:06 CEST 2017)
Upstream Package Changes
testing community i686: 819 new and 777 removed package(s)
testing core i686: 19 new and 19 removed package(s)
testing core x86_64: 19 new and 19 removed package(s)
testing multilib x86_64: 3 new and 3 removed package(s)
testing extra i686: 635 new and 627 removed package(s)
testing extra x86_64: 636 new and 628 removed package(s)
testing community x86_64: 820 new and 778 removed package(s)
Overlay Package Changes
testing community i686: 37 new and 41 removed package(s)
testing core i686: 1 new and 2 removed package(s)
testing core x86_64: 1 new and 2 removed package(s)
testing extra i686: 28 new and 77 removed package(s)
testing extra x86_64: 28 new and 77 removed package(s)
testing community x86_64: 69 new and 73 removed package(s)
A detailed list of package changes can be found here.
Re: 2017-06-11 - QT v5.9, Perl Rebuild, KDE Apps v17.04.2, Deepin (Testing Update)
Alles gut!
