2017-03-22 - Elogind, Plasma, Deepin, Manjaro-Architect (Testing Update)
Hatte keine Probleme.
0
Keine Stimmen
1
100%
0
Keine Stimmen
Hi community,
With this update Marcus offers a complete switch from Consolekit to Elogind for our Openrc-editions. More information can be found in the dedicated thread.
Also some new Plasma 5.9.4 packages have arrived aswell as updates for Bumblebee, Python and Haskell.
Release 0.8.2 of our new CLI net-installer Manjaro-Architect is now available and has been stabilized after some quite thorough testing lately. More details on this project here.
Latest pacman-mirrors update fixes some bugs with the new ranking functionality. More information on the latest development with this to be found here and here
Deepin is currently experiencing some heavy updating - not without issues I'm afraid, but I'm doing my best to keep everything as smooth as possible there. I expect things to calm down again in the near future with deepin development and am planning on releasing another Manjaro-Deepin edition then ...
Please test and give us feedback as usual
Current supported Kernels
linux310 3.10.105
linux312 3.12.72
linux316 3.16.42
linux318 3.18.48 [EOL]
linux41 4.1.39
linux44 4.4.55
linux48 4.8.17 [EOL]
linux49 4.9.16
linux410 4.10.4
linux-RT-LTS 4.4.53_rt66
linux-RT 4.9.13_rt12
Package Updates
testing community i686: 326 new and 311 removed package(s)
testing community x86_64: 326 new and 311 removed package(s)
testing core i686: 7 new and 7 removed package(s)
testing core x86_64: 7 new and 7 removed package(s)
testing extra i686: 81 new and 88 removed package(s)
testing extra x86_64: 81 new and 88 removed package(s)
testing multilib x86_64: 5 new and 9 removed package(s)
Detailed package changes can be found here.
Re: 2017-03-22 - Elogind, Plasma, Deepin, Manjaro-Architect (Testing Update)
Bei mir gab es folgende Fehlermeldung
Fehler: Konnte den Vorgang nicht durchführen (In Konflikt stehende Dateien)
libglvnd: /usr/lib/libEGL.so existiert im Dateisystem
libglvnd: /usr/lib/libEGL.so.1 existiert im Dateisystem
libglvnd: /usr/lib/libEGL.so.1.0.0 existiert im Dateisystem
libglvnd: /usr/lib/libGL.so existiert im Dateisystem
libglvnd: /usr/lib/libGL.so.1 existiert im Dateisystem
libglvnd: /usr/lib/libGLESv1_CM.so existiert im Dateisystem
libglvnd: /usr/lib/libGLESv1_CM.so.1 existiert im Dateisystem
libglvnd: /usr/lib/libGLESv2.so existiert im Dateisystem
libglvnd: /usr/lib/libGLESv2.so.2 existiert im Dateisystem
libglvnd: /usr/lib/libGLESv2.so.2.0.0 existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libEGL.so existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libEGL.so.1 existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libEGL.so.1.0.0 existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGL.so existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGL.so.1 existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGLESv1_CM.so existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGLESv1_CM.so.1 existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGLESv2.so existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGLESv2.so.2 existiert im Dateisystem
lib32-libglvnd: /usr/lib32/libGLESv2.so.2.0.0 existiert im Dateisystem
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
Hab dann folgenden Befehl eingegeben.
sudo pacman -S libglvnd lib32-libglvnd mhwd --force
Danach das Update normal gestartet.
Ich habe bis jetzt nichts negatives festgestellt.
Roberto
CPU: Intel Core i5 M 540
GPU: Intel Core Processor Integrated Graphics
Kernel: 5.6.1-artix1-1 x86_64
Beitrag von Roberto »
Gestern hatte ich genau die gleichen Fehlermeldungen.
Heute habe ich das Update normal (also ohne --force) neu gestartet und es lief ohne Probleme durch.
Lenovo X220 | 128 GB SSD Kingston SV300S3 | 8 GB Ram DDR 3 1333MHz
