2017-02-24 - Kernels, CVE-2017-6074, Gstreamer, Surface 3 Pro (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
the issue with Catalyst seems to be now fixed:
(==) Parse error on line 5 of section OutputClass in file
/usr/share/X11/xorg.conf.d/fglrx-outputclass.conf"ModulePath" is not a
valid keyword in this section.Fatal server error:(EE) no screens
found(EE)
So what are todays updates then? There was a request to support Surface Pro3 OOTB. So we added the needed patches and made it work. With Manjaro 17.0-rc2 it will be possible to test it with a fresh ISO. It will be released later today. Therefore you have time till EOB to test this update-pack and give your feedback.
We updated some of our kernels and included needed fixes for the CVE-2017-6074 - DCCP double-free vulnerability. We still have not decided if we will patch EOL-tagged kernels at all ...
We also updated gstreamer, python packages, modified mesa a little and pushed out some more deepin packages.
Please test and give us feedback as usual
Current supported Kernels
linux310 3.10.105
linux312 3.12.70
linux316 3.16.40
linux318 3.18.48 [EOL]
linux41 4.1.38
linux44 4.4.51
linux48 4.8.17 [EOL]
linux49 4.9.12
linux410 4.10.0
linux-RT-LTS 4.4.47_rt59
linux-RT 4.9.9_rt9
Package Updates (Fri Feb 24 08:42:07 CET 2017)
testing community i686: 43 new and 44 removed package(s)
testing community x86_64: 43 new and 44 removed package(s)
testing core i686: 6 new and 6 removed package(s)
testing core x86_64: 6 new and 6 removed package(s)
testing extra i686: 75 new and 71 removed package(s)
testing extra x86_64: 75 new and 71 removed package(s)
testing multilib x86_64: 4 new and 4 removed package(s)
Re: 2017-02-24 - Kernels, CVE-2017-6074, Gstreamer, Surface 3 Pro (Testing Update)
Ohne Probleme!
