2017-02-23 - Deepin, NetworkManager, Haskell, Python (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
the issue with Catalyst seems to be now fixed:
(==) Parse error on line 5 of section OutputClass in file
/usr/share/X11/xorg.conf.d/fglrx-outputclass.conf"ModulePath" is not a
valid keyword in this section.Fatal server error:(EE) no screens
found(EE)
So what are todays updates then? Well, some more Deepin updates, small changes to networkmanager and the usual haskell and python updates. Nothing fancy I hope. In regard of the CVE-2017-6074 - DCCP double-free vulnerability, v4.9.11 and v4.10.0 are already patched for this one. Other kernel series have to follow. We will see how fast we can solve this. EOL-tagged kernels we most likely won't patch ...
Please test and give us feedback as usual
Current supported Kernels
linux310 3.10.105
linux312 3.12.70
linux316 3.16.39
linux318 3.18.48 [EOL]
linux41 4.1.38
linux44 4.4.50
linux48 4.8.17 [EOL]
linux49 4.9.11
linux410 4.10.0
linux-RT-LTS 4.4.47_rt59
linux-RT 4.9.9_rt9
Package Updates (Thu Feb 23 07:35:43 CET 2017)
testing community i686: 76 new and 69 removed package(s)
testing community x86_64: 77 new and 70 removed package(s)
testing extra i686: 12 new and 12 removed package(s)
testing extra x86_64: 12 new and 12 removed package(s)
testing multilib x86_64: 0 new and 2 removed package(s)
Re: 2017-02-23 - Deepin, NetworkManager, Haskell, Python (Testing Update)
Ohne Probleme!
