2017-01-04 - Broadcom-wl, Brisk-menu, OpenVPN, Thunderbird (Stable Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hello, Manjaro Community!
The year is still very young, yet we already have 2017's first stable update waiting here for you:
Included is the first release of the brand new brisk-menu, developed for the Mate desktop by the Solus team
. Tell us your thoughts about it's usability in the Mate development thread
Thunderbird received a security update that we fast forwarded already yesterday, our realtime-kernel received its last update before we will upgrade its basekernel from linux48 to linux49 (linux-rt-manjaro-4.9_rt1 is already available on the unstable branch).
Our installer broadcom-wl driver, calamares, flightgear and some ruby packages were updated aswell as openVPN, which ... might need your attention:
!! NOTICE !!
OpenVPN 2.4.0 update may require administrative interaction
The upgrade to openvpn 2.4.0 makes changes that are incompatible with
previous configuration. Take special care if you depend on VPN
connectivity for remote access! Administrative interaction is required:
Configuration is expected in sub directories now. Move your files
from /etc/openvpn/ to /etc/openvpn/server/ or /etc/openvpn/client/.
The plugin lookup path has changed. Remove extra plugins/ from relative
paths.
The systemd unit openvpn@.service was replaced with
openvpn-client@.service and openvpn-server@.service. Restart and
reenable accordingly.
This does not affect the functionality of networkmanager, connman
or qopenvpn.
kind regards
Bernhard Landauer and the Manjaro team
Package changes
core i686: 12 new and 12 removed packages
core x86_64: 12 new and 12 removed packages
extra i686: 113 new and 118 removed packages
extra x86_64: 113 new and 118 removed packages
community i686: 269 new and 246 removed packages
community x86_64: 286 new and 264 removed packages
multilib x86_64: 8 new and 11 removed packages
Current supported kernels
linux310 3.10.104
linux312 3.12.69
linux316 3.16.39
linux318 3.18.46
linux41 4.1.37
linux44 4.4.39
linux48 4.8.15
linux49 4.9.0
linux-RT-LTS 4.4.38_rt49
linux-RT 4.8.15_rt10
Re: 2017-01-04 - Broadcom-wl, Brisk-menu, OpenVPN, Thunderbird (Stable Update)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.9.0-1-MANJARO x86_64 (64 bit)
           Desktop: Xfce 4.12.3 Distro: Manjaro Linux
m-bostaurus
Kernel: 510
Has thanked: 51 times
Been thanked: 12 times
Beitrag von m-bostaurus »
Habe wegen Krankheit erst bei zwei meiner ungefähr 8 Betriebssysteme aktualisiert. Alles ging gut bis auf das Seafile-Paket aus dem AUR. Das musste de- und anschließend installiert werden (https://aur.archlinux.org/packages/seafile-client/; Beiträge von a-bostaurus). Dank an das Entwicklerteam!
