2017-01-02 - Calamares, Cinnamon, Broadcom-WL, Brisk Menu (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
we had a blast with 2016. Lets continue for this year also. We ended with a bang, lets start also with one 2017!
With this update we renewed calamares, thunderbird, cinnamon, broadcom-wl, some ruby packages and flightgear. We worked close together with the development team of Solus, to present you Brisk, a new implementation of a clean, efficient, and modern menu for the MATE Desktop. Give us your feedback on how usuable this new menu is for you here .
Please also pay attention in regard of openvpn! As usual, post us your findings and start a great new year!
kind regards,
Philip and the Manjaro Development Team
Current supported kernels
linux310 3.10.104
linux312 3.12.69
linux316 3.16.39
linux318 3.18.46
linux41 4.1.37
linux44 4.4.39
linux48 4.8.15
linux49 4.9.0
linux-RT-LTS 4.4.38_rt49
linux-RT 4.8.15_rt10
Overlay package chnages (Mon Jan 2 18:51:02 CET 2017)
testing community i686: 6 new and 12 removed package(s)
testing extra i686: 15 new and 21 removed package(s)
testing extra x86_64: 15 new and 21 removed package(s)
testing community x86_64: 23 new and 29 removed package(s)
testing multilib x86_64: 0 new and 3 removed package(s)
Upstream package changes (Mon Jan 2 18:44:02 CET 2017)
testing core i686: 10 new and 10 removed package(s)
testing core x86_64: 10 new and 10 removed package(s)
testing multilib x86_64: 5 new and 5 removed package(s)
testing extra x86_64: 93 new and 92 removed package(s)
testing extra i686: 93 new and 92 removed package(s)
testing community i686: 145 new and 117 removed package(s)
testing community x86_64: 145 new and 118 removed package(s)
NOTICE
OpenVPN 2.4.0 update requires administrative interaction
The upgrade to openvpn 2.4.0 makes changes that are incompatible with
previous configurations. Take special care if you depend on VPN
connectivity for remote access! Administrative interaction is required:
Configuration is expected in sub directories now. Move your files
from /etc/openvpn/ to /etc/openvpn/server/ or /etc/openvpn/client/.
The plugin lookup path changed, remove extra plugins/ from relative
paths.
The systemd unit openvpn@.service was replaced with
openvpn-client@.service and openvpn-server@.service. Restart and
reenable accordingly.
This does not affect the functionality of networkmanager, connman
or qopenvpn.
Re: 2017-01-02 - Calamares, Cinnamon, Broadcom-WL, Brisk Menu (Testing Update)
Ohne Probleme!
