2016-10-13 - Plasma 5.8.1, Framework 5.27, Gnome 3.22.1 (Testing Update)
FOR SYSTEMD USERS HAVING STILL v231-1 INSTALLED, IT IS RECOMMENDED TO USE PACMAN, AS X-SESSION MIGHT GET LOST DUE THIS UPDATE. THEREFORE WE SUGGEST TO FOLLOW OUR UPDATE RECOMMENDATION. YOU CAN TRY IF FOLLOWING CMD MIGHT CRASH YOUR SYSTEM:
sudo systemctl --system daemon-reexec
Hi community,
With the current testing Update we added Plasma 5.8 LTS.
https://youtu.be/LgH1Clgr-uE
Plasma 5.8 is the first Long Term Support edition of its flagship desktop software, Plasma. This marks the point where the developers and designers are happy to recommend Plasma for the widest possible audience be they enterprise or non-techy home users.
If you tried a KDE desktop previously and have moved away, now is the time to re-assess, Plasma is simple by default, powerful when needed.
DOWNLOAD KDE ISO
https://youtu.be/LhY7rpWXm1Y
Also we introduce Gnome 3.22.1, which brings comprehensive Flatpak support. GNOME Software can install and update Flatpaks, GNOME Builder can create them, and the desktop provides portal implementations to enable sandboxed applications. Improvements to core GNOME applications include support for batch renaming in Files, sharing support in GNOME Photos, an updated look for GNOME Software, a redesigned keyboard settings panel, and many more.
DOWNLOAD GNOME ISO
Additionally we worked on our xorg-stack and fixed some reported issues.
Archlinux upstream fixes are now from: Thu Oct 13 18:52 CEST 2016
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Packages for our next stable review can be found here.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
KDE users should default to Maia theme:
ufw
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.103
Linux312 3.12.64
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.42
Linux41 4.1.33
Linux44 4.4.24
Linux46 4.6.7 [EOL]
Linux47 4.7.7
Linux48 4.8.1
Linux-RT-LTS 4.4.23_rt33
Linux-RT 4.6.7_rt14
Package Changes
testing community i686: 350 new and 318 removed package(s)
testing community x86_64: 350 new and 318 removed package(s)
testing core i686: 8 new and 10 removed package(s)
testing core x86_64: 8 new and 10 removed package(s)
testing extra i686: 401 new and 394 removed package(s)
testing extra x86_64: 402 new and 395 removed package(s)
testing multilib x86_64: 11 new and 10 removed package(s)
Re: 2016-10-13 - Plasma 5.8.1, Framework 5.27, Gnome 3.22.1 (Testing Update)
Ohne Probleme!
