coming closer to our next stable release we adjusted some packages. With this update pack we have renewed haskell, deepin, lxqt, libreoffice, nvidia legacy drivers and networkmanager. Also some of our kernels got updated including v4.8.1. Additional work went into our steam clients. We offer now our own steam-manjaro and upstream versions of steam including native libraries. Some work went into our OpenRC packages. Also we updated our manjaro-tools, so we can prepare our first release candidate of Manjaro Linux 16.10. As usual we also provide the upstream updates, such as python2, packagekit and multimedia codecs.
Archlinux upstream fixes are now from: Tue Oct 05 19:26 CEST 2016
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Packages for our next stable review can be found here.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.103
Linux312 3.12.64
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.24
Linux46 4.6.7 [EOL]
Linux47 4.7.7
Linux48 4.8.1
Linux-RT-LTS 4.4.23_rt33
Linux-RT 4.6.7_rt14
Package Changes
stable community i686: 394 new and 380 removed package(s)
stable community x86_64: 427 new and 414 removed package(s)
stable core i686: 26 new and 25 removed package(s)
stable core x86_64: 26 new and 25 removed package(s)
stable extra i686: 379 new and 378 removed package(s)
stable extra x86_64: 379 new and 378 removed package(s)
stable multilib x86_64: 40 new and 31 removed package(s
