coming closer to our next stable release we adjusted some packages. With this update pack we have the final v4.8 kernel added to our repositories. Some work went into our OpenRC packages. As usual we also provide the upstream updates, such as python2, packagekit and multimedia codecs.
Archlinux upstream fixes are now from: Mon Oct 03 10:57 CEST 2016
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Packages for our next stable review can be found here.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.23
Linux46 4.6.7 [EOL]
Linux47 4.7.6
Linux48 4.8.0
Linux-RT-LTS 4.4.21_rt30
Linux-RT 4.6.7_rt14
Package Changes
testing community i686: 26 new and 21 removed package(s)
testing community x86_64: 26 new and 21 removed package(s)
testing core i686: 4 new and 4 removed package(s)
testing core x86_64: 4 new and 4 removed package(s)
testing extra i686: 29 new and 29 removed package(s)
testing extra x86_64: 29 new and 29 removed package(s)
testing multilib x86_64: 4 new and 1 removed package(s)
