2016-10-02 - Kernels, Manjaro Tools, Deepin, NM, LibreOffice, (Testing Update)
Hi community,
coming closer to our next stable release we adjusted some packages. With this update pack we have renewed haskell, deepin, lxqt, libreoffice, nvidia legacy drivers and networkmanager. Also some of our kernels got updated. Additional work went into our steam clients. We offer now our own steam-manjaro and upstream versions of steam including native libraries.
Archlinux upstream fixes are now from: Sun Oct 02 02:35 CEST 2016
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Detailed package changes can be viewed here.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
KDE users should default to Maia theme:
ufw
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.23
Linux46 4.6.7 [EOL]
Linux47 4.7.6
Linux47 4.8-rc8
Linux-RT-LTS 4.4.21_rt30
Linux-RT 4.6.7_rt14
Package Changes
testing community i686: 218 new and 201 removed package(s)
testing community x86_64: 234 new and 219 removed package(s)
testing core i686: 11 new and 13 removed package(s)
testing core x86_64: 11 new and 13 removed package(s)
testing extra i686: 223 new and 224 removed package(s)
testing extra x86_64: 223 new and 224 removed package(s)
testing multilib x86_64: 22 new and 12 removed package(s)
Re: 2016-10-02 - Kernels, Manjaro Tools, Deepin, NM, LibreOffice, (Testing Update)
Ohne Probleme!
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
[quote="Blueriver"]
Ohne Probleme!
Bei mir ebenfalls.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Alles gut...... ???
Roberto
CPU: Intel Core i5 M 540
GPU: Intel Core Processor Integrated Graphics
Kernel: 5.6.1-artix1-1 x86_64
Beitrag von Roberto »
Die Updates sind wie immer geschmeidig durchgelaufen  ???
Lenovo X220 | 128 GB SSD Kingston SV300S3 | 8 GB Ram DDR 3 1333MHz
