Mozilla seems to be really fast. Another Point-Release of Firefox just came out. The Vertex-Maia theme issue seems to be solved by now and the menu gets displayed as normal. We updated some of our kernels (4.4.22, 4.7.5) and released the brand new LxQT 0.11. Some cool features to mention:
Under Openbox an LXQt specific configuration file ~/.config/openbox/lxqt-rc.xml is used from now on.
The taskbar of LXQt, is now behaving well on multi-monitor systems
The main menu comes with a search feature.
A desktop entry file and can as such be dragged into an instance of plugin-quicklaunch
The release is introducing pavucontrol-Qt, the Qt port of PulseAudio’s mixer pavucontrol
Archlinux upstream fixes are now from: Sun Sep 25 08:23 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.22
Linux46 4.6.7 [EOL]
Linux47 4.7.5
Linux47 4.8-rc7
Linux-RT-LTS 4.4.21_rt30
Linux-RT 4.6.7_rt13
Package Changes
testing community i686: 141 new and 136 removed package(s)
testing community x86_64: 158 new and 153 removed package(s)
testing core i686: 8 new and 8 removed package(s)
testing core x86_64: 8 new and 8 removed package(s)
testing extra i686: 143 new and 142 removed package(s)
testing extra x86_64: 143 new and 142 removed package(s)
testing multilib x86_64: 3 new and 3 removed package(s)
