2016-09-15 - Linux 3.14 [EOL], Plasma 5.7.5, Python2, XFCE4-GTK
Hi community,
we are already working on our next update-pack for you guys. KDE friends might be happy about the new Plasma 5.7.5 release. We updated the coding framework gambas3, some of our python packages, bumped spl/zfs to 0.6.5.8 and added partly XFCE based on GTK3. As security fix we have an updated flashplugin. The kernel 3.14 series is now delcared EOL, so we recommend to move on. The Gnome guys working hard on networkmanager to get it back stable again. Therefore we updated our package to the lastest git-snapshot. Please report your results with it.
Archlinux upstream fixes are now from: Thu Sep 15 03:44 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. A detailed list of package changes can be found here.
Kind regards,
Troubleshoots
  • Catalyst-Utils needs now three new packages: catalyst-video, catalyst-input and catalyst-server.
  • Catalyst-Video provides some needed drivers like Intel and Vesa, since we have some hybrid systems too
  • Catalyst-Input provides the needed input drivers
  • Catalyst-Server provides the compatible Xorg-Server
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
You can install it with:
KDE users should default to Maia theme:
ufw
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Quelle von manjaro.org
Zuletzt geändert von manjarofan am Donnerstag 15. September 2016, 10:15, insgesamt 1-mal geändert.
