Manjaro Ellada was a great release so far. However we are already working on our next release we codenamed Fringilla. During the ongoing development we found already some things we can also push to our current stable branch.
One of the bigger changes is the switch to a newer Xorg-Stack including Xorg-Server 1.18 series. We even might adopt Xorg-Server 1.19 series real soon. Is Catalyst gone then? No, we managed to re-introduce matching packages for Catalyst drivers, so they are still working. However, we might have missed some raw edges. Please report them. Nvidia got updated to 370.28, which supports now Pascal Overclocking, PRIME Sync and PixelShiftMode.
For our KDE fans we updated all apps to 16.08 series. The first point release 16.08.1 got now added to our repositories. Plasma on the other hand is now at 5.7.4. Also LibreOffice is now at 5.2.1. Another big issue was NetworkManager. We think we have also managed that problem. Report otherwise if you still have issues with your WLAN.
Most of the browsers, like Firefox and Chromium got updated to the latest releases. This goes also for Wine, Mate, Haskell and Python packages. To round this update-pack up, we switched now to our 0.13.x series of manjaro-tools. The effort is now to provide profile-settings you can install side by side. This will improve the ability to switch between our several desktop environment configurations and enables us to provide an enhanced Net-Install ISO soon. Be tuned for the new modules we write for the installer framework Calamares.
Archlinux upstream fixes are now from: Fri Sep 9 18:31 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. A detailed list of package changes can be found here.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=noIssues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.78
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.20
Linux46 4.6.7 [EOL]
Linux47 4.7.3
Linux-RT-LTS 4.4.19_rt27
Linux-RT 4.6.7_rt11
Package Changes
community i686: 446 new and 457 removed package(s)
community x86_64: 465 new and 475 removed package(s)
core i686: 27 new and 27 removed package(s)
core x86_64: 27 new and 27 removed package(s)
extra i686: 901 new and 920 removed package(s)
extra x86_64: 901 new and 920 removed package(s)
multilib x86_64: 22 new and 24 removed package(s)
