Manjaro Ellada was a great release so far. However we are already working on our next release we codenamed Fringilla. During the ongoing development we found already some things we can also push to our current branches in stable and testing.
One of the bigger changes is the switch to a newer Xorg-Stack including Xorg-Server 1.18 series. We even might adopt Xorg-Server 1.19 series real soon. Is Catalyst gone then? No, we managed to re-introduce matching packages for Catalyst drivers, so they are still working. However, we might have missed some raw edges. Please report them. Nvidia got updated to 370.28, which supports now Pascal Overclocking, PRIME Sync and PixelShiftMode.
For our KDE fans we updated all apps to 16.08 series. The first point release 16.08.1 got now added to our repositories. Plasma on the other hand is now at 5.7.4. Also LibreOffice is now at 5.2.1. Another big issue was NetworkManager. We think we have also managed that problem with 1.4.1dev+33+gc87b89b. Report otherwise if you still have issues with your WLAN.
Most of the browsers, like Firefox and Chromium got updated to the latest releases. This goes also for Wine, Mate, Haskell and Python packages. To round this update-pack up, we switched now to our 0.13.x series of manjaro-tools. The effort is now to provide profile-settings you can install side by side. This will improve the ability to switch between our several desktop environment configurations and enables us to provide an enhanced Net-Install ISO soon. Be tuned for the new modules we write for the installer framework Calamares.
Archlinux upstream fixes are now from: Fri Sep 9 06:39 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. A detailed list of package changes can be found here.
Kind regards,
Troubleshoots
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.78
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.20
Linux46 4.6.7 [EOL]
Linux47 4.7.3
Linux-RT-LTS 4.4.19_rt27
Linux-RT 4.6.7_rt11
Package Changes
testing community i686: 435 new and 454 removed package(s)
testing community x86_64: 454 new and 472 removed package(s)
testing core i686: 26 new and 27 removed package(s)
testing core x86_64: 26 new and 27 removed package(s)
testing extra i686: 895 new and 914 removed package(s)
testing extra x86_64: 895 new and 914 removed package(s)
testing multilib x86_64: 22 new and 24 removed package(s)
