This is more or less a smaller update. We restored the Nvidia 370.23 in our testing branch. Firefox got updated to version 48.0.2 and some python packages got updated. Also we finished our Calamares installer.
The focus of the Calamares 2.4 development cycle was fixing bugs and polishing existing functionality, including locales management and partitioning, but we’re also shipping an all-new package selection module.
Highlights of this release include:
added support for reusing an existing /home partition if detected in the /etc/fstab file of an already installed operating system;
new netinstall module which offers a choice of packages to install;
rewritten large portions of the locale module, with new locale and timezone autodetection functionality and smarter management of locale.conf values;
added support for an already mounted loop filesystem as source for the unpackfs operation;
improved handling of partition colors in the partitioning interfacewhen operating on logical partitions;
fixed a user name validation issue which could in some specific situations cause a failed installation;
improved defaults in several configuration files;
improved bootloader deployment on EFI systems with an existing EFI system partition;
countless other bug fixes.
We recommend to use manjaro-tools 0.12.4 with manjaro-live 20160731 in combination. Matching ISO-Profils you may find in our 16.08-preX branch. Master-Branch is not recommend to use with the calamares package. Therefore only the calamares-dev package currently works.
Archlinux upstream fixes are now from: Thu Aug 25 08:46 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.77
Linux316 3.16.37
Linux318 3.18.40
Linux41 4.1.31
Linux44 4.4.19
Linux46 4.6.7 [EOL]
Linux47 4.7.2
Linux-RT-LTS 4.4.17_rt25
Linux-RT 4.6.7_rt11
Package changes
testing community i686: 25 new and 19 removed package(s)
testing community x86_64: 27 new and 21 removed package(s)
testing core i686: 1 new and 1 removed package(s)
testing core x86_64: 1 new and 1 removed package(s)
testing extra i686: 17 new and 17 removed package(s)
testing extra x86_64: 17 new and 17 removed package(s)
testing multilib x86_64: 5 new and 4 removed package(s)
