2016-08-23 - Linux 47, Intel, Python, Deepin (Testing Update)
Hi community,
this another roundup-patch-set for Sundays update. We updated kernel 4.7 series, some deepin and python packages and released the latest Intel driver. Nothing scary with this small update.
Archlinux upstream fixes are now from: Tue Aug 23 07:21 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
Troubleshoots
Issues with updating MATE
LibreOffice and GTK3
GTK3
KDE users should default to Maia theme:
ufw
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.77
Linux316 3.16.36
Linux318 3.18.39
Linux41 4.1.30
Linux44 4.4.19
Linux46 4.6.7 [EOL]
Linux47 4.7.2
Linux-RT-LTS 4.4.17_rt25
Linux-RT 4.6.5-rt10
Package changes
testing community i686: 48 new and 49 removed package(s)
testing community x86_64: 47 new and 48 removed package(s)
testing core i686: 12 new and 10 removed package(s)
testing core x86_64: 12 new and 10 removed package(s)
testing extra i686: 40 new and 41 removed package(s)
testing extra x86_64: 40 new and 41 removed package(s)
testing multilib x86_64: 1 new and 2 removed package(s)
Re: 2016-08-23 - Linux 47, Intel, Python, Deepin (Testing Update)
Ohne Probleme!
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
Man traut es sich garnicht zu schreiben  >:(  Update und alles läuft wie geschmiert.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Alles, wiedermal, perfekt durch gelaufen.  ???
