Also our graphical package managers Pamac and Octopi gained both a new point release with needed fixes. Systemd is now at v231, Lumina Desktop got to its third beta release, VirtualBox is now at v5.1.2 plus Wine is now at 1.9.15. We sum this update-pack up with haskell and python packages and needed fixes to Mesa.
Archlinux upstream fixes are now from: Mon Aug 01 17:37 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install. Detailed package changes can be viewed here.
Kind regards,
Troubleshoots
GTK3
You can install it with:
QT apps style with GTK
ufw
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.74
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.16
Linux45 4.5.7 [EOL]
Linux46 4.6.5
Linux47 4.7.0
Package changes
community i686: 281 new and 284 removed package(s)
community x86_64: 288 new and 289 removed package(s)
core i686: 23 new and 23 removed package(s)
core x86_64: 23 new and 23 removed package(s)
extra i686: 197 new and 177 removed package(s)
extra x86_64: 197 new and 177 removed package(s)
multilib x86_64: 7 new and 7 removed package(s)
