[heiko@heiko-g750js ~]$ inxi -Fz
System:
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
Distro: Manjaro Linux
Machine:
Type: Laptop System: ASUSTeK product: G750JS v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
ID-1: BAT0 charge: 52.9 Wh (100.0%) condition: 52.9/77.0 Wh (68.7%)
volts: 14.8 min: 14.8
CPU:
Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 840 min/max: 800/3400 cores: 1: 800 2: 800 3: 800
4: 1124 5: 799 6: 800 7: 800 8: 800
Graphics:
Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: intel dri: i965
gpu: i915 resolution: 1: N/A 2: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2)
Audio:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: yes
Sound Server-2: PipeWire v: 0.3.65 running: yes
Network:
Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
IF: wlp3s0 state: up mac: <filter>
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
Device-1: IMC Networks BCM20702A0 type: USB driver: btusb
Drives:
Local Storage: total: 1.6 TiB used: 778.88 GiB (47.6%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
ID-1: / size: 233.38 GiB used: 66.56 GiB (28.5%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sdb1
Swap:
Sensors:
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Info:
Processes: 273 Uptime: 2d 30m Memory: 30.81 GiB used: 3.91 GiB (12.7%)
Shell: Bash inxi: 3.3.25
Bis vor einem Monat lief alles problemlos. Zwischenzeitlich sind ein oder zwei größere Updates gekommen. Keine Ahnung, ob damit etwas geändert wurde, dass jetzt für diesen Effekt sorgt.
Ich habe "ARandR" auch schon mal komplett deinstalliert und neu installiert - leider ohne Verbesserung.
Irgendwelche Ideen, was die Ursache sein könnte?
Gruß Heiko
