ich habe Manjaro in einer VM mit den Oberflächen XFCE, MATE und KDE Plasma installiert.
Beim Login-Screen kann ich eine Oberfläche auswählen, aber er landet immer auf der XFCE-Oberfläche.
$ sudo systemctl status sddm
● sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2022-06-09 19:35:02 CEST; 19min ago
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 375 (sddm)
Tasks: 4 (limit: 3552)
Memory: 134.0M
CPU: 34.789s
CGroup: /system.slice/sddm.service
├─ 375 /usr/bin/sddm
└─ 1803 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{6868a6f6>
Jun 09 19:46:30 VM-manjaro sddm[375]: Authenticated successfully
Jun 09 19:46:30 VM-manjaro sddm-helper[1828]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Jun 09 19:46:30 VM-manjaro sddm-helper[1828]: pam_unix(sddm:session): session opened for user opa(uid=1000) by >
Jun 09 19:46:30 VM-manjaro sddm-helper[1828]: pam_env(sddm:session): deprecated reading of user environment ena>
Jun 09 19:46:30 VM-manjaro sddm-helper[1828]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyri>
Jun 09 19:46:30 VM-manjaro sddm-helper[1828]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Jun 09 19:46:30 VM-manjaro sddm[375]: Auth: sddm-helper exited successfully
Jun 09 19:46:30 VM-manjaro sddm[375]: Greeter stopped.
Jun 09 19:46:30 VM-manjaro sddm-helper[1828]: Starting: "/usr/share/sddm/scripts/Xsession \"mate-session\""
Jun 09 19:46:30 VM-manjaro sddm[375]: Session startedCode: Alles auswählen
$ cat /etc/sddm.conf
[Autologin]
# Whether sddm should automatically log back into sessions when they exit
Relogin=false
# Name of session file for autologin session (if empty try last logged in)
Session=
# Username for autologin session
User=
[General]
# Halt command
HaltCommand=/usr/bin/systemctl poweroff
# Input method module
InputMethod=
# Initial NumLock state. Can be on, off or none.
# If property is set to none, numlock won't be changed
# NOTE: Currently ignored if autologin is enabled.
Numlock=none
# Reboot command
RebootCommand=/usr/bin/systemctl reboot
[Theme]
# Current theme name
Current=
# Cursor theme used in the greeter
CursorTheme=
# Number of users to use as threshold
# above which avatars are disabled
# unless explicitly enabled with EnableAvatars
DisableAvatarsThreshold=7
# Enable display of custom user avatars
EnableAvatars=true
# Global directory for user avatars
# The files should be named <username>.face.icon
FacesDir=/usr/share/sddm/faces
# Theme directory path
ThemeDir=/usr/share/sddm/themes
[Users]
# Default $PATH for logged in users
DefaultPath=/bin:/usr/bin:/usr/local/bin
# Comma-separated list of shells.
# Users with these shells as their default won't be listed
HideShells=
# Comma-separated list of users that should not be listed
HideUsers=
# Maximum user id for displayed users
MaximumUid=60000
# Minimum user id for displayed users
MinimumUid=1000
# Remember the session of the last successfully logged in user
RememberLastSession=true
# Remember the last successfully logged in user
RememberLastUser=true
# When logging in as the same user twice, restore the original session, rather than create a new one
ReuseSession=false
[Wayland]
# Enable Qt's automatic high-DPI scaling
EnableHiDPI=false
# Path to a script to execute when starting the desktop session
SessionCommand=/usr/share/sddm/scripts/wayland-session
# Directory containing available Wayland sessions
SessionDir=/usr/share/wayland-sessions
# Path to the user session log file
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
# Path to a script to execute when starting the display server
DisplayCommand=/usr/share/sddm/scripts/Xsetup
# Path to a script to execute when stopping the display server
DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=false
# The lowest virtual terminal number that will be used.
MinimumVT=1
# Arguments passed to the X server invocation
ServerArguments=-nolisten tcp
# Path to X server binary
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
# Directory containing available X sessions
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
# Path to the Xauthority file
UserAuthFile=.Xauthority
# Path to xauth binary
XauthPath=/usr/bin/xauth
# Path to Xephyr binary
XephyrPath=/usr/bin/XephyrWo muß ich da etwas ändern?
Ch. Hanisch
