[Stable Update] 2021-03-08- Kernels, Plasma 5.21.2, Haskell, Kodi, Grub, KDE-Dev
Hatte keine Probleme.
6
46%
4
31%
3
23%
Insgesamt abgegebene Stimmen: 13
philm, post:1, topic:56877 hat geschrieben: Hello community,
Another **stable** branch update with some usual updates for you.
*All the best to all of our females in our community. Linux wouldn’t be great without all those [Women in Linux ](https://www.womeninlinux.org/)! #stayhome, #staysafe, #stayhealthy*
* Most of the **Kernels** got updated
* **Grub** got some needed [security updates ](https://wiki.ubuntu.com/SecurityTeam/Kn ... Bypass2021)
* For fans of KDE Software we have now [Plasma 5.21.2 ](https://kde.org/announcements/plasma/5/5.21.2/)
* **Kodi** [19.0 Matrix ](https://kodi.tv/article/kodi-190-matrix-release) got released
* Other regular upstream updates including **python** and **haskell**
Get our latest daily developer images now from Github: [Plasma ](https://github.com/manjaro-plasma/download/releases), [Gnome ](https://github.com/manjaro-gnome/download/releases), [XFCE ](https://github.com/manjaro-xfce/download/releases). You can also help us with the [**Stable-Review** images ](https://github.com/manjaro/release-review/releases), so the upcoming installer ISOs are solid for Newcomers!
**Our current supported kernels**
* linux44 4.4.258
* linux49 4.9.258
* linux414 4.14.222
* linux419 4.19.177
* linux54 5.4.101
* linux59 5.9.16 [EOL]
* linux510 5.10.19
* linux511 5.11.2
* linux54-rt 5.4.93_rt51
* linux59-rt 5.9.1_rt19
**Packages Changes** (Wed Mar 3 10:49:15 CET 2021)
* stable community x86_64: 1229 new and 1209 removed package(s)
* stable core x86_64: 17 new and 17 removed package(s)
* stable extra x86_64: 288 new and 348 removed package(s)
* stable kde-unstable x86_64: 241 new and 240 removed package(s)
* stable multilib x86_64: 25 new and 25 removed package(s)
A detailed list of all package changes can be found https://gitlab.manjaro.org/-/snippets/600/raw.
Has thanked: 67 times
Re: [Stable Update] 2021-03-08- Kernels, Plasma 5.21.2, Haskell, Kodi, Grub, KDE-Dev
Moin
Nach dem letzten update bootet mein Laptop nicht mehr,schwarzer Bildschirm.
Booten nur möglich wenn ich die Festplatte direckt anwähle.
Auch das neue update brachte keine Verbesserung.
Ich werde dann wohl auch beim Laptop auf Void umsteigen.Schneller und zuverlässiger.
Auf wiedersehen Manjaro
Alles bestens! :)
Holle
CPU: AMD® Ryzen™ 7 PRO 4750G
GPU: Renoir Rx Vega 8
Kernel: LTS
Has thanked: 7 times
Been thanked: 16 times
Beitrag von Holle »
Auch bei mir alles top. :)
Ist bei mir noch nicht angekommen.
maroco
GPU: Intel HD Graphics 620
Kernel: 6.6
Desktop-Variante: Xfce; Labwc
Has thanked: 9 times
Been thanked: 53 times
Beitrag von maroco »
Bei mir erschien beim Start von grub die Fehlermeldung "can't find command os-prober". Konnte ich beheben, indem ich in meiner /etc/default/grub die Zeile
GRUB_DISABLE_OS_PROBER="true"
zu
GRUB_DISABLE_OS_PROBER="false"
änderte und anschließend
sudo update-grub
ausführte.
Holle
Kernel: LTS
Beitrag von Holle »
@Josef_K
Liegt evtl. an der Serverliste. Persönlich habe ich folgende eingestellt:
sudo pacman-mirrors --country Germany --api --protocol https && sudo pacman -Syyu
charly700
CPU: Intel Core i5-10400
Has thanked: 124 times
Been thanked: 42 times
Beitrag von charly700 »
maroco hat geschrieben: Montag 8. März 2021, 19:11 Bei mir erschien beim Start von grub die Fehlermeldung "can't find command os-prober". Konnte ich beheben, indem ich in meiner /etc/default/grub die Zeile
zu
sudo update-grub
ausführte.
Danke das hat geholfen, wobei der Eintrag
bei mir gar nicht vorhanden war.
Aber ich verstehe Manjaro derzeit sowie so nicht. Mittlerweile gibt es fast bei jedem Update Probleme mit Funktionen die Standardmäßig eigentlich ohne Zutun Funktionieren sollte.
Was wollen die Macher von Manjaro damit erreichen, wenn Grundlegende Funktionen (Und dazu gehört Grub in Multiboot Systemen) nicht mehr Funktionieren?
Und der Link welcher im originalen Forum da angegeben wird ist auch keine Hilfe.
Ich finde es Schade in welche Richtung Philm sich mit seinem Team entwickelt.
Mir ist schon klar das ein Rolling Release immer wieder mal manuelle Eingriffe erfordern aber das nimmt in letzter Zeit leider zu.
Früher konnte man Manjaro einfach übers Terminal updaten und hatte so gut wie keine Probleme aber derzeit muss man vor einem Update unbedingt in die Releasnotes schauen damit man nicht überrascht wird und wieder irgendwas nicht Funktioniert. Das hat schon mit Cups angefangen wo man nach dem Update manuell die Dienste, welche einfach nur einen neuen Namen bekommen haben, eneablen musste. Warum geht sowas nicht beim Update automatisch?
Gruß Charly
nijila
CPU: AMD Ryzen 5 PRO 4650G
Kernel: stable, actual
GPU Treiber: amdgpu
Has thanked: 16 times
Been thanked: 8 times
Beitrag von nijila »
Heute früh gab es schon ein dickes Update, neugestartet und keine Probleme, super!
Gerade eben kam noch ein Grub Update herein, einen Neustart hat er nicht empfohlen, ich habe davor aber sicherheitshalber ein Timeshift Backup erstellt. Wird schon gut gehen :)
Fast alle Kodi 18 Addons sind nicht mehr kompatibel zur Version 19 und lassen sich leider auch nicht updaten.
Eventuell kommt da aber noch was.
Lina
CPU: AMD Ryzen 7 4700U with Radeon Graphics
GPU: AMD Renoir
Kernel: 6.12.x Manjaro
Desktop-Variante: KDE Plasma 6.5.x
GPU Treiber: video-linux
Been thanked: 12 times
Beitrag von Lina »
Ich hatte weder mit den Updates, noch mit dem Kernel an sich Probleme.
Allerdings lief danach displaylink(Arch) bei mir nicht mehr. Offensichtlich ist die aktuelle Version noch nicht für den 5.11er-Kernel angepasst (evdi ließ sich nicht zum Laufen bringen). Habe deshalb erst einmal wieder auf den 5.10er zurückgeswitcht.
Holle hat geschrieben: Montag 8. März 2021, 19:12 @Josef_K
Ist bei mir gleich, bis auf --api und --protocol.
MichaelP
CPU: AMD Ryzen 9 5900X
GPU: NVIDIA GTX 3080 Ti
Kernel: 6.7.0
Desktop-Variante: KDE 5.27.10
GPU Treiber: NVIDIA 545.29.06
Has thanked: 17 times
Been thanked: 28 times
Beitrag von MichaelP »
Hi zusammen,
mit GRUB_DISABLE_OS_PROBER=false konnte ich dank Eurer Beiträge das Bootmenü restaurieren!
Bin aber auf die Devs sauer, Manjaro wird mehr und mehr zur Bastelecke!
@djeli: hast Recht, war zum Jahreswechsel nach dem NVIDIA-Desaster auch kurz vorm Absprung.
Übrigens: Kann mit Spectacle keine Screenshots mehr erstellen (Kernel 5.11.2-1), Spectacle-Fenster öffnet sich nicht.
In KSysGuard sehe ich aber den Task... :o
Hat jemand ähnliche Probleme oder gar einen Tipp?
Gruß Michael
Holle
Kernel: LTS
Beitrag von Holle »
MichaelP hat geschrieben: Dienstag 9. März 2021, 15:34 Übrigens: Kann mit Spectacle keine Screenshots mehr erstellen (Kernel 5.11.2-1), Spectacle-Fenster öffnet sich nicht.
Spectacle klappt bei mir einwandfrei, kann ich nicht nachvollziehen auf meinem System.
Bei der Nvidia Geschichte sehe ich den Fehler nicht bei Manjaro.
https://www.archlinux.de/news/33601-Pro ... -Linux-5-9
Der Ursache ging von Nvidia aus und andere Distris hatten deshalb auch Probleme.
Borrtux
GPU: NVIDIA GeForce 930M
Kernel: 5.10.18-1-MANJARO
Has thanked: 44 times
Been thanked: 14 times
Beitrag von Borrtux »
Ja, ich hatte auch das Problem mit grub.
Meine Frau wollte "ihr" Windows starten - ging nicht - lief gleich in Manjaro hoch - Katastrophe!!!
Konnte aber (dank dieses Forums) mit
in etc/default/grub das Problem lösen.
Das war die Kurzversion ;)
Es grüßt euch borrtux
