So, mal eine Frage an die vim-Experten hier.
Wo kriege ich eine vim-Version mit Clipboard Unterst
vim
Radaku
Re: vim
Der Tipp mit gvim war gar nicht so schlecht
Note that while you'll need the version of Vim that supports X, you don't need to run it as an X application--you can run it in a terminal as gvim -v. That will launch Vim in vi or terminal mode but with access to the X clipboard. You can make this easier with an alias: alias vim='gvim -v'.HP Compaq 6910p / Kernel: 4.5.5-1-MANJARO x86_64 / Intel Core2 Duo T7300 / Intel Mobile GM965/GL960 Integrated Graphics Controller
