sudo pacman -Syu
sudo pacman -Syu
sudo pacman-mirrors -f && sudo pacman -Syyu
[sudo] Passwort für claus:
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
1.571 Germany : https://ftp.halifax.rwth-aachen.de/manjaro/
1.444 Germany : ftp://ftp.halifax.rwth-aachen.de/manjaro/
0.646 Germany : https://mirror.atysleaks.org/manjaro/
0.689 Germany : http://mirror.atysleaks.org/manjaro/
1.014 Germany : https://mirror.netzspielplatz.de/manjaro/packages/
0.657 Germany : https://mirror.alpix.eu/manjaro/
0.794 Germany : https://manjaro.moson.org/
0.924 Germany : http://manjaro.moson.org/
1.419 Germany : https://mirror.23media.com/manjaro/
0.617 Germany : http://mirror.23media.com/manjaro/
0.515 Germany : https://manjaro.moson.eu/
0.329 Germany : http://manjaro.moson.eu/
0.544 Germany : https://manjaro.re/
0.406 Germany : http://manjaro.re/
1.255 Germany : ftp://manjaro.re/
::INFO Writing mirror list
::Germany : https://manjaro.moson.eu/stable/$repo/$arch
::Germany : https://mirror.23media.com/manjaro/stable/$repo/$arch
::Germany : https://mirror.alpix.eu/manjaro/stable/$repo/$arch
::Germany : https://mirror.atysleaks.org/manjaro/stable/$repo/$arch
::Germany : https://manjaro.moson.org/stable/$repo/$arch
::Germany : https://mirror.netzspielplatz.de/manjaro/packages/stable/$repo
::Germany : https://manjaro.re/stable/$repo/$arch
::Germany : https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
:: Synchronisiere Paketdatenbanken...
core 169,4 KiB 193 KiB/s 00:01 [######################] 100%
extra 2018,2 KiB 371 KiB/s 00:05 [######################] 100%
community 6,3 MiB 267 KiB/s 00:24 [######################] 100%
multilib 189,4 KiB 272 KiB/s 00:01 [######################] 100%
:: Starte vollständige Systemaktualisierung...
Es gibt nichts zu tun
pamac-manager
pamac-manager
** Message: 19:45:56.590: flatpak_plugin.vala:345: refreshing flathub appstream data
(pamac-manager:18153): GLib-GIO-CRITICAL **: 19:45:56.833: g_application_run: assertion 'acquired_context' failed
sudo pacman --overwrite="*" -S flatpak
Warnung: flatpak-1.9.2-1 ist aktuell -- Reinstalliere
Löse Abhängigkeiten auf...
Pakete (1) flatpak-1.9.2-1
Gesamtgröße der installierten Pakete: 8,52 MiB
Größendifferenz der Aktualisierung: 0,00 MiB
(1/1) Prüfe Schlüssel im Schlüsselring [######################] 100%
(1/1) Überprüfe Paket-Integrität [######################] 100%
(1/1) Lade Paket-Dateien [######################] 100%
(1/1) Prüfe auf Dateikonflikte [######################] 100%
(1/1) Überprüfe verfügbaren Festplattenspeicher [######################] 100%
:: Verarbeite Paketänderungen...
(1/1) Installiere flatpak [######################] 100%
:: Starte post-transaction hooks...
(1/4) Creating system user accounts...
(2/4) Reloading system manager configuration...
(3/4) Arming ConditionNeedsUpdate...
(4/4) Reloading system bus configuration...
[claus@manjaro-desktop ~]$ flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo
[claus@manjaro-desktop ~]$ flatpak update
Looking for updates…
Info: org.gnome.Platform//3.34 is end-of-life, with reason:
The GNOME 3.34 runtime is no longer supported as of 14th August 2020. Please ask your application developer to migrate to a supported platform.
Applications using this runtime:
uk.jnthn.backgammony
Info: org.freedesktop.Platform//1.6 is end-of-life, with reason:
The Freedesktop 1.6 runtime is no longer supported and does not receive security updates. Please ask your application developer to migrate to a supported runtime.
Info: org.freedesktop.Platform.ffmpeg//1.6 is end-of-life, with reason:
ID Zweig Op Remote Download
1. io.freetubeapp.FreeTube stable u flathub < 121,4Â MB
2. org.gnome.Platform.Locale 3.36 u flathub < 323,1Â MB (partial)
3. org.gnome.Platform 3.36 u flathub < 326,0Â MB
4. org.kde.KStyle.Adwaita 5.14 u flathub < 6,6Â MB
5. org.kde.KStyle.Adwaita 5.15 u flathub < 6,2Â MB
6. org.freedesktop.Platform.Locale 1.6 r
7. org.freedesktop.Platform.ffmpeg 1.6 r
8. org.freedesktop.Platform 1.6 r
Proceed with these changes to the system installation? [Y/n]: n
pamac remove flatpakCode: Alles auswählen
sudo rm -r /var/lib/flatpakCode: Alles auswählen
rm -r ~/.local/share/flatpak
