2019-08-13 - Kernels, XFCE 4.14, KDE, LibreOffice 6.3, Discord, Mesa (Stable Update)
Hatte keine Probleme.
6
75%
0
Keine Stimmen
2
25%
Insgesamt abgegebene Stimmen: 8
Hello community,
I am happy to announce another Stable Update. Mostly we have XFCE 4.14, LibreOffice 6.3 and Kernel updates with this one.
Update news
This update holds the following changes:
Most of the Kernels got updated to minigate CVE-2019-1125 “SWAPGS”
XFCE got updated to 4.14
Plasma got updated to version 5.16.4
Deepin got updated to version 5.0. For more details you can find here.
LibreOffice is now at 6.3.0
Mesa is now at 19.1.4
fpakman got some nice updates. We will rename it to bauh with the next update
Discord is now part of our official repositories
Lazarus IDE is now at 2.0.4
Kodi got some updated addons
Gimp got updated help files
We worked with upstream on a new package-selction-tool for Calamares
Certbot is now at 0.37.0
KDE-Git packages got updated to their latest git-commits
Pamac supports now to build packages from Web-URL links
libinput is now at 1.14.0
Latest python, haskell and upstream updates
Latest efforts by KDE can be reviewed via our current KDE-Dev ISO or current KDE-Vanilla ISO
Manjaro Juhraya ISOs got updated, including flatpak and snap support pre-activated. Office can be selected during installation between libreoffice-still or freeoffice: XFCE, KDE, Gnome
Give us the usual feedback and let us know what you think about this update.
Current supported Kernels
linux316 3.16.70
linux44 4.4.189 (no legacy nvidia-340 module!)
linux49 4.9.189
linux414 4.14.138
linux419 4.19.66
linux51 5.1.21 [EOL]
linux52 5.2.8 (no catalyst module!)
linux53 5.3-rc4 (not all modules build yet!)
linux419-rt 4.19.50_rt22
linux50-rt 5.0.21_rt16
A list of all package changes can be found here.
Known issues and solutions
This is a wiki post; please edit as necessary.
Please, consider subscribing to the Stable Updates Announcements RSS feed
Pango doesn't support bitmap fonts anymore
Applications that use Pango and that are configured to use bitmap fonts now only show rectangles instead of characters. This affects popular terminal emulator setups, because many people use fonts like Terminus in applications like GNOME Terminal. We recommend to switch fonts or downgrade pango.
https://gitlab.gnome.org/GNOME/pango/issues/386
Asian/CJK characters display as blocks
Install noto-fonts-cjk or another font of your choice. The problem seems related to a ttf-droid update.
https://bugs.archlinux.org/task/63205
libbloom>=1.6-2 update requires manual intervention
(Taken from Arch Linux website, 2019-07-11 by Felix Yan. Source: https://www.archlinux.org/news/libbloom ... ervention/)
The libbloom package prior to version 1.6-2 was missing a soname link. This has been fixed in 1.6-2, so the upgrade will need to overwrite the untracked soname link created by ldconfig. If you get an error
libbloom: /usr/lib/libbloom.so.1 exists in filesystem
when updating, use
pacman -Suy --overwrite /usr/lib/libbloom.so.1
to perform the upgrade.
Tux333
CPU: AMD Phaenom 9600
GPU: nvidia Ge Force 210
Kernel: 4.19.30
GPU Treiber: video-nvidia-340
Re: 2019-08-13 - Kernels, XFCE 4.14, KDE, LibreOffice 6.3, Discord, Mesa (Stable Update)
Beitrag von Tux333 »
Download-Größe gesamt: 611,8 kB
Gesamtgröße installiert: 56,6 MB
Transaktion anwenden ? [j/N] j
Herunterladen von xfce4-panel-gtk3 (4.14.0-1)...
303 Bytes/611,8 kB
Warnung: Konnte einige Dateien nicht übertragen
Fehler: Vorgang konnte nicht abgeschlossen werden: Konnte Datei 'xfce4-panel-gtk3-4.14.0-1-x86_64.pkg.tar.xz' nicht von mirror.xeonbd.com übertragen : The requested URL returned error: 404 Not Found
Dieser Fehler war bei mir vorhanden, hat jetzt aber dennoch beim 3. Versuch alles funktioniert.
Alles bestens. :)
Jean-Paul
CPU: --
GPU: --
Kernel: --
Desktop-Variante: --
GPU Treiber: --
Has thanked: 42 times
Been thanked: 48 times
Beitrag von Jean-Paul »
Alles bestens, Update sauber durchgelaufen. Prima! :D
Peter
CPU: Intel Core i5-6200U
GPU: Card-1: Intel HD Graphics 520 Card-2: NVIDIA GM108M [GeForc
Kernel: 5.4.35-1-MANJARO x86_64
GPU Treiber: video-hybrid-intel-nvidia-bumblebee
Beitrag von Peter »
Schon seit dem Update vom 1.8.19 startet skype nicht mehr, welches über das herecura Repo installiert war. Auch ein aktuelles Update des Programms brachte keine Lösung. Skype startet einfach gar nicht.
Siehe auch hier: viewtopic.php?f=13&t=2283&p=13694#p13694
