Hi community,
Welcome to another stable update. So what do we have with this one?
We worked again on Deepin and updated some packages
VirtualBox is now at 5.2.22
Latest Gimp 2.10.8
Firefox is now on it’s eight beta of v64 series
KDE Apps is now at 18.08.3
KDE Plasma is now at 5.14.3
Latest Cinnamon packages added
The usual upstream haskell, and python rebuilds/updates
#bladebook - shipping to Switzerland this fall!
Currently we are working on a new Manjaro-Hardware project, the Bladebook Fall 2018. It will be powered by Manjaro KDE v18.0 and the latest Intel Apollo Lake Quad-Core HD APU. Having a fanless metal material (cassis gold-rose), a eMMC as storage (additional M2-SSD possible) and will have a long battery life. You can now pre-order your #bladebook when you live in Switzerland. We will start shipping in CW46 and will take orders from you now. Find out more on our hardware page or the shop.
Manjaro v18.0.1 Preview1 released!
If you are curious about the latest Manjaro-Illyria 18.0.1 release, you now have the opportunity to download XFCE Edition with the latest 4.13 packages, aswell as our most recent styling efforts. Our KDE fans may try our KDE Edition with the latest KDE v5.14 instead. And our GNOME fans may try our Gnome Edition with the latest GNOME v3.30.
Current supported Kernels
linux316 3.16.59
linux318 3.18.124 [EOL]
linux44 4.4.162
linux49 4.9.135
linux414 4.14.79
linux417 4.17.19 [EOL]
linux418 4.18.17
linux419 4.19.1
linux414-rt 4.14.78_rt47
linux416-rt 4.16.18_rt11
linux418-rt 4.18.16_rt9
2018-11-11 - Systemd, KDE Apps & Plasma, Deepin, Cinnamon, Grub (Stable Update)
Themen Author - Moderator
Zuletzt geändert von Blueriver am Sonntag 11. November 2018, 14:06, insgesamt 1-mal geändert.
Re: 2018-11-11 - Systemd, KDE Apps & Plasma, Deepin, Cinnamon, Grub (Stable Update)
Auch wieder ohne Probleme.
Peter
- CPU: Intel Core i5-6200U
- GPU: Card-1: Intel HD Graphics 520 Card-2: NVIDIA GM108M [GeForc
- Kernel: 5.4.35-1-MANJARO x86_64
- Desktop-Variante: KDE Plasma 5.18.4
- GPU Treiber: video-hybrid-intel-nvidia-bumblebee
- Has thanked: 5 times
- Been thanked: 1 time
Totale Probleme mit Plasma. Habe am 13.11. ca. 22 Uhr das update im tty mit sudo pacman -Syu durchgeführt. Es lief fehlerfrei durch. Der Neustart funktionierte auch.
Ich habe totale Probleme mit Fenstern. Firefox und Thunderbird öffnen sich. Aber manchmal erst nach Minuten. Selbst beim Tabwechsel in Firefox oder hier beim Eingeben der Nachricht gibt es einen Freeze von mind. 20s.
Beim schließen von z.B. Firefox gibt es nach einer Weile eine Fehlermeldung mit Plasma reagiert nicht. Beim Thunderbird auch. Ein öffnen von Dolphin dauert manchmal ewig, bis das Programm aufgeht. Klicke ich auf ein Bild, dauert es gerade mehrere Minuten, bis das Bild in Gwenview angezeigt wird. Die Festplatte rattert die ganze Zeit. Beim KSysguard und im Terminal mit top wird nur eine geringe Prozessorlast hauptsächlich von Firefox angezeigt. Klicke ich aber auf Systemlast sind oft alle 4 Kerne auf 100%.
Bei baloo_file_extractor steht inaktiv auf Festplatte und 1.670.456k Gemeinsamer Speicher.
Auch beim Ausführen von top im Terminal dauerte es eben 20s bis das Programm startete und etwas anzeigte.
Herunterfahren des Rechners dauert auch mehrere Minuten.
Ich habe gesehen, dass es am 13.11. wohl ein weiteres Update gab. Ich habe ja die Hoffnung, dass evtl. verschieden aktuelle Programme installiert wurden. Allerdings gibt es auch Stunden später keine weiteren Updates, wenn ich mit Octopi auf Datenbank synchronisieren klicke.
Wie kann ich feststellen, welchen Mirror ich gerade verwende? Es sind noch nicht alle gesynct.
Hallo Peter,
hier kannst du sehen welche Mirrors schon synchronisiert sind.
https://repo.manjaro.org
Welchen Du gerade nutzt steht in
etc/pacman.d/mirrorlist
der oberste wird benutzt.
Peter
[quote="Blueriver"]
Hallo Peter,
Der verwendete Mirror ist synchronisiert. Es gibt keine weiteren Updates. Ich bin also auf dem neuesten Stand.
Ich habe mit Octopi mal ein paar Pakete angeguckt und ich habe die neueste Version, die hier angekündigt wurde: https://forum.manjaro.org/t/stable-upda ... xfce/65343
Es muss also an etwas anderem liegen. Die Webseite wire.com (ein Messenger) meldete gerade, dass sie lokalen Speicher benötige und nicht geladen werden kann. Erst nach mehrmaligem aktualisieren ging es dann.
Bei diesen minutenlangen Aussetzern hatte ich in zwei Fällen keine Rahmen mehr um die Anwendung (Firefox).
Eben brauchte der Firefox mehrere Minuten zum beenden und dann meldete sich der Mozilla Crash Manager.
3 von 4 Kernen laufen fast permanent mit 100% wir im Systemmonitor angezeigt.
Ich habe mal einen extra Thread aufgemacht: https://www.manjaro-forum.de/index.php/ ... 810.0.html
Hallo Peter,
Zuletzt geändert von Peter am Mittwoch 14. November 2018, 09:30, insgesamt 1-mal geändert.
Peter
Problemursache gefunden baloo_file und baloo_file_extractor siehe Thread hier:
https://www.manjaro-forum.de/index.php/ ... 811.0.html
