2018-10-25 - Linux 4.19, KDE Plasma 5.14.2, Xorg,Gnome 3, Grub (Stable Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hi community,
Welcome to another stable update. Since this update is huge we recommend to install it from within a terminal: pamac upgrade or sudo pacman -Syu
So what do we have with this one?
The kernel is now at v4.19.0 and got some BFQ fixes
grub gained functionality to automatically hide the menu as needed and will replace grub-quiet
Pamac is now at v7.2.0  and supports PKGUILD editing
KDE Plasma is now at 5.14.2
A security update for xorg-server
More Gnome 3.30.2 packages got added
We updated most of Deepin packages
We added the second beta release of Firefox v64
The usual upstream updates incl. python and haskell
#bladebook - shipping to Switzerland this fall!
Currently we are working on a new Manjaro-Hardware project, the Bladebook Fall 2018. It will be powered by Manjaro KDE v18.0 and the latest Intel Apollo Lake Quad-Core HD APU. Having a fanless metal material (cassis gold-rose), a eMMC as storage (additional M2-SSD possible) and will have a long battery life. You can now pre-order your #bladebook when you live in Switzerland. We will start shipping in CW46 and will take orders from you in CW44. Find out more on our hardware page.
#rc-release - 18.0 will be available in late October!
If you are curious about the latest state of development for the upcoming Manjaro-Illyria 18.0 release, you now have the opportunity to download a rc-build of Manjaro-Xfce 18.0 including the latest 4.13 packages, aswell as our most recent styling efforts. Our KDE fans may try our rc-build with the latest KDE v5.14 instead. And our GNOME fans may try our rc-build with the latest GNOME v3.30.
Current supported Kernels
linux316 3.16.59
linux318 3.18.124 [EOL]
linux44 4.4.162
linux49 4.9.135
linux414 4.14.78
linux417 4.17.19 [EOL]
linux418 4.18.16
linux419 4.19.0
linux414-rt 4.14.71_rt44
linux416-rt 4.16.18_rt11
A detailed list of all changes can be found here.
Zuletzt geändert von Blueriver am Freitag 26. Oktober 2018, 07:10, insgesamt 1-mal geändert.
m-bostaurus
Kernel: 510
Has thanked: 51 times
Been thanked: 12 times
Re: 2018-10-25 - Linux 4.19, KDE Plasma 5.14.2, Xorg,Gnome 3, Grub (Stable Update)
Beitrag von m-bostaurus »
Das Update lief auf allen meinen Rechnern sauber durch; ebenso die Umstellung auf den Kernel 4.19
Quinix
Beitrag von Quinix »
lief bei meinem läppi auch sauber durch.
eigentlich wie immer die ganzen jahre.
manjao ist halt ein feines und gutes linux.  und eben mein linux hafen. ;-)
ich will und nutze nichts anderes mehr.
