20180428 - `filesystem`, kernels, KDE, VirtualBox, WINE, ZSH [Stable Update x32]
Hello i686ers!
The most important aspect of this set is the update to the filesystem package. The changes made should be checked carefully to ensure any customisation you have made is retained, in, for example:
/etc/hosts
/etc/hostname
/etc/locale.conf
/etc/locale.gen
/etc/vconsole.conf
There’s an update to glibc and GCC; everything should be working with the new glibc version, but keep an eye out.
There’s also the usual kernel updates, and in terms of other notable updates KDE 18.04 has arrived, along with updates to VirtualBox, WINE, and ZSH.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series Version
linux316 3.16.56
linux41 4.1.51
linux44 4.4.129
linux49 4.9.96
linux414 4.14.36
archlinux32
Using manjaro32 and spotted an out-of-date Manjaro package? First, check the Manjaro GitHub sources for core, extra, and community. If it’s in the GitHub sources, it’s a Manjaro package. You can check whether the package is in the archlinux32 repos directly: https://mirror.archlinux32.org/i686/ Alternatively, check the Arch package list to see whether the package is one likely to be built by archlinux32. If it’s a Manjaro package, and it’s out-of-date, report here.
What about security updates?
What about installer images?
Phil very kindly updated the preview installer images:
osdn.net
Downloading File /xfce/17.1.7-rc1 - Manjaro Linux (32-Bit) - OSDN
Free download page for Project Manjaro Linux (32-Bit)'s 17.1.7-rc1.Manjaro is a user-friendly Linux distribution based on the independently developed Arch operating system. Within the Linux com...
