2018-03-17 - xorgproto, kernels, systemd, LibreOffice [Stable Update x32]
Hello i686ers!
This is another large update set which updates kernels 4.9 and 4.14 (with extramodules), systemd, KDE, LibreOffice, Haskell packages, Python modules …
Of particular note is the xorgproto transition. You will be prompted to replace several of the following packages:
bigreqsproto  compositeproto  damageproto  dmxproto  dri2proto  dri3proto
fixesproto  fontsproto  glproto  inputproto  kbproto  presentproto  printproto
randrproto  recordproto  renderproto  resourceproto  scrnsaverproto  videoproto
xcmiscproto  xextproto xf86dgaproto  xf86driproto  xf86miscproto  xf86vidmodeproto
xineramaproto  xproto
This is expected, say “yes” to all.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine)
Available kernels
Series Version
linux316 3.16.55
linux41 4.1.49
linux44 4.4.120
linux49 4.9.87
linux414 4.14.27
archlinux32
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc2/xfce/ Be aware, 17.1.1-rc2 is built against t…
There will be a new release as soon as I refresh myself on how to do it. :slight_smile:
