2018-02-15 - Kernels, OpenJDK 8 [Stable Update x32]
Hello i686ers!
This is a smaller update set which updates kernels 4.1, 4.9, and 4.14 (with extramodules) as well as OpenJDK 8.
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.49
linux44 4.4.115
linux49 4.9.81
linux414 4.14.19
archlinux32
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc1/xfce/ Be aware, 17.1.1-rc1 is built against t…
There will be a new release as soon as I refresh myself on how to do it. :slight_smile:
