QuelleHello i686ers!
This set of packages includes a large set of updates from upstream (thank you!) as well as new 4.4, 4.9, and 4.14 kernel versions. There are several other Manjaro-specific package updates, and for anyone running a 32-bit system with an NVIDIA GPU there’s a driver update to version 390.25 too.
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.115
linux49 4.9.80
linux414 4.14.17
archlinux32
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc1/xfce/ Be aware, 17.1.1-rc1 is built against t…
There will be a new release as soon as I refresh myself on how to do it.
2018-02-07 - Big upstream update, kernels, extramodules [Stable Update x32]
Themen Author - Moderator
