2018-02-02 - VLC Nightly, Architect, PHP7, Themes (Testing Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hi community,
this seems to be a smaller update comparing to our last testing update. We have some work done withour Architect Installer, updated VLC-Nightly to v3.0-rc9 and had some regular upstream updates like PHP7 and several Theme updates.
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
linux316 3.16.52
linux318 3.18.93 [EOL]
linux41 4.1.48
linux44 4.4.114
linux49 4.9.79
linux414 4.14.16
linux415 4.15.0
linux-RT-LTS 4.14.15_rt13
linux-RT 4.14.15_rt13
Package Updates (Fri Feb 2 07:01:15 CET 2018)
testing community x86_64: 49 new and 50 removed package(s)
testing core x86_64: 1 new and 1 removed package(s)
testing extra x86_64: 98 new and 157 removed package(s)
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Re: 2018-02-02 - VLC Nightly, Architect, PHP7, Themes (Testing Update)
Beitrag von linuxkumpel »
Wie eigentlich immer, alles ohne Einschränkungen. Die beiden Maschinchen surren nach dem Update.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Bei mir läuft auch alles prima.
