QuelleHello i686ers!
This set of package updates includes updates for Firefox 58.0.1 and Thunderbird 52.6, along with kernel updates and associates extramodules.
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.113
linux49 4.9.78
linux414 4.14.15
archlinux32
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc1/xfce/ Be aware, 17.1.1-rc1 is built against t…
There will be a new release as soon as I refresh myself on how to do it.
2018-01-31 - Kernels, Firefox, Thunderbird [Stable Update x32]
Themen Author - Moderator
Katedongjai
Re: 2018-01-31 - Kernels, Firefox, Thunderbird [Stable Update x32]
I have benefited from reading this content a lot. I want to tell everyone.
