2018-01-28 - Linux415-Extra-Modules, Steam, Haskell (Testing Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hi community,
again we have a smaller set of packages today. Bernhard and I worked on the Real-Time Kernels and updated them both to v4.14 series. We use now meta-pkgs to define them for you. Some work went into our Steam-Client, we managed to get more extra-modules compiled for our v4.15 kernel series and added the needed Python and Haskell rebuilds/updates.
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
linux316 3.16.52
linux318 3.18.92 [EOL]
linux41 4.1.48
linux44 4.4.113
linux49 4.9.78
linux412 4.12.14 [EOL]
linux413 4.13.16 [EOL]
linux414 4.14.14
linux415 4.15-rc9
linux-RT-LTS 4.14.15_rt12
linux-RT 4.14.15_rt12
Package Updates (Sun Jan 28 08:08:57 CET 2018)
testing community x86_64: 123 new and 107 removed package(s)
testing core x86_64: 6 new and 6 removed package(s)
testing extra x86_64: 17 new and 13 removed package(s)
testing multilib x86_64: 4 new and 4 removed package(s)
Re: 2018-01-28 - Linux415-Extra-Modules, Steam, Haskell (Testing Update)
Alles gut.
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
Und jetzt
Manjaro 17.1.3 Hakoila
Läuft alles  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
