2018-01-25 - Firefox 58, r8168 extramodule, rust, TLP [Stable Update x32]
This set of package updates includes the new Firefox 58, an updated driver for r8168-based network devices, and a new TLP release.
You already had the new Palemoon release so you know about that already…
This set is a fairly small one. I suspect the next one will be quite a bit bigger.
Have fun!
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.112
linux49 4.9.77
linux414 4.14.14
archlinux32
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc1/xfce/ Be aware, 17.1.1-rc1 is built against t…
There will be a new release as soon as I refresh myself on how to do it. :slight_smile:
Carballal
Re: 2018-01-25 - Firefox 58, r8168 extramodule, rust, TLP [Stable Update x32]
Beitrag von Carballal »
The information I get from reading is very useful.
