2018-01-21 - Kernels and extramodules, printer drivers, [Stable Update x32]
Hello i686ers!
This set of package updates includes new point-releases for kernels 4.4, 4.9, and 4.14 with their associated extramodules. There’s an update to Palemoon and the foomatic printer drivers, and updates to NVIDIA drivers, pacui, and Atom.
Have fun!
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.112
linux49 4.9.77
linux414 4.14.14
archlinux32
If you find manjaro32 useful please consider donating to, or helping out with, archlinux32
. It’s a small team taking on a huge project and any help will no doubt be very much appreciated.
How do I get it?
These steps should no longer be necessary
If you’re already running a 32-bit installation, and haven’t already migrated, you should shortly get a manjaro-system update which will transition you to the new setup (it should automate the following steps).
Otherwise, edit your /etc/pacman-mirrors.conf and change (or set):
Branch = x32-stable
making sure there is no comment marker (#) at the start of the line. Then, update your mirror list, install the keyring package, and update:
pacman-mirrors -c all
pacman -Sy archlinux32-keyring-transition
pacman -S archlinux32-keyring
pacman -Syu
archlinux32-keyring-transition is signed by the Arch devs and allows you to install archlinux32-keyring which contains the keys that sign all archlinux32 packages.
archlinux32-keyring replaces archlinux32-keyring-transition.
What about package updates?
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. I may also trim the supported package list to save effort, depending on frequency of updates to packages and packagers who volunteer to help out. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc1/xfce/ Be aware, 17.1.1-rc1 is built against t…
There will be a new release as soon as I refresh myself on how to do it. :slight_smile:
