2017-08-25 - Thunderbird, Pamac, Calamares, Plasma 5 (Stable Update)
Hatte keine Probleme.
4
80%
0
Keine Stimmen
1
20%
Insgesamt abgegebene Stimmen: 5
Hi community,
with Thunderbird v52.3.0 lot of security issues got fixed. Guillaume released Pamac v5.1.0 and we updated KDE Plasma 5 to v5.10.5. Last but not least we updated Calamares to its latest point release.
Please report back and give us feedback for given changes made to our repositories.
kind regards
Lisa McCoy
Manjaro Release Manager
Current supported Kernels
linux310 3.10.107
linux312 3.12.74 [EOL]
linux316 3.16.46
linux318 3.18.66 [EOL]
linux41 4.1.43
linux44 4.4.83
linux48 4.8.17 [EOL]
linux49 4.9.44
linux410 4.10.17 [EOL]
linux411 4.11.12 [EOL]
linux412 4.12.8
linux413 4.13-rc6 (x86_64)
linux-RT-LTS 4.9.40_rt30 (x86_64)
linux-RT 4.11.12_rt10 (x86_64)
Package Updates (Thu Aug 24 09:14:06 CEST 2017)
stable community i686: 115 new and 113 removed package(s)
stable community x86_64: 119 new and 117 removed package(s)
stable core i686: 4 new and 4 removed package(s)
stable core x86_64: 4 new and 4 removed package(s)
stable extra i686: 152 new and 153 removed package(s)
stable extra x86_64: 152 new and 153 removed package(s)
stable multilib x86_64: 1 new and 1 removed package(s)
[url=http://Quelle
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Re: 2017-08-25 - Thunderbird, Pamac, Calamares, Plasma 5 (Stable Update)
Beitrag von linuxkumpel »
Update lief ohne Probleme durch.  :D
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Ebenfalls ohne Probleme.
m-bostaurus
Kernel: 510
Has thanked: 51 times
Been thanked: 12 times
Beitrag von m-bostaurus »
Auch bei mir auf allen Rechnern alles gut.
Wie immer alles bestens.... ???
Peter
CPU: Intel Core i5-6200U
GPU: Card-1: Intel HD Graphics 520 Card-2: NVIDIA GM108M [GeForc
Kernel: 5.4.35-1-MANJARO x86_64
GPU Treiber: video-hybrid-intel-nvidia-bumblebee
Beitrag von Peter »
Probleme beim booten. Nach kurzer Anzeige von manjaro und den Punkten darunter wird der Bildschirm schwarz. Etwas später werden von weiß auf grün blinkende Striche sichtbar. Diese sind in einer Linie und alle 5? Striche sind 5mal hintereinander zu sehen. Kurz danach ist kurz ein schwarzer Bildschirm mit abgerbeiteten Befehlen sichtbar und danach der normale Anmeldebildschirm von KDE.
Weiterhin kann der Laptop nach dem Ruhezustand nicht mehr aufwachen. Der Bildschirm bleibt schwarz, keine Tastatureingabe möglich und das Touchpad reagiert auch nicht. Der Mauszeiger ist aber zu sehen.
Ich kann dann nur lange auf den Ausschalter drücken und neu booten.
Ich war 3 Wochen in Urlaub und hab dann das Update mit sudo pacman -Syu im tty F3 durchgeführt. Es gab keine Fehlermeldungen.
Ich brauche den Rechner dringend zum arbeiten. Der Ruhezustand beim zuklappen muss wieder funktionieren!
Eben ist mir aufgefallen, dass der Rechner auch nur jedes zweite Mal hochfährt. Ich habe ihn mal heruntergefahren und neu gestartet. Nach kurzer Anzeige von manjaro und den Punkten darunter wird das Bild schwarz und nichts passiert mehr. Ich muss dann lange auf den Ausschalter drücken. Wenn ich danach wieder den Schalter betätige zum hochfahren, wird der KDE Anmeldebildschirm angezeigt und ich kann mich einloggen und arbeiten.
Ich habe eben mal auf reboot geklickt und der Laptop fuhr hoch. Nur das blinken der Punkte under dem Schriftzug manjaro beim booten fand nicht statt. Der Bildschirm wurde kurz schwarz und zeigte dann aber gleich den KDE Anmeldebidlschirm. Komisch.
Soll ich das eigentlich hier posten oder als besser als separaten Thread posten?
Ich habe einen extra Thread aufgemacht. Bitte hier antworten: http://www.manjaro-forum.de/index.php/topic,1065.0.html
Zuletzt geändert von Peter am Donnerstag 31. August 2017, 20:08, insgesamt 1-mal geändert.
Hallo Peter,
[quote="Peter"]
Mein persönlicher Senf dazu: lieber seperaten Thread aufmachen. So geht das zu leicht unter.
Viele Grüße gosia
Peter
Beitrag von Peter »
[quote="gosia"]
Hallo Peter,
[quote="Peter"]
Viele Grüße gosia
Hab ich gemacht: http://www.manjaro-forum.de/index.php/topic,1065.0.html
