2017-04-09 - OpenRC, Thunderbird, Kernels, Deepin, Mate (Testing Update)
Hatte keine Probleme.
1
50%
0
Keine Stimmen
1
50%
Insgesamt abgegebene Stimmen: 2
Hi community,
seems with the new mesa-stack we created some issues on some systems of yours. Also with the release of v17.0.1 we were able to bring some systems back to life. Others managed to fix their systems on their own. Well, sometimes changing some bigger in the system, even we have tested it thru and thru on several systems shows that some older systems sometimes have issues. This issue might be solved with the depreciation of i686 later this year.
We are currently thinking about i686 in general and if we should adopt Archlinux32 somehow. Let us know about your feelings about this matter.
For this update we have some new Kernels, updates to Mate and Deepin, lot of new stuff for our OpenRC fans and the latest Thunderbird.
Please test and give us feedback as usual
Current supported Kernels
linux310 3.10.105
linux312 3.12.72
linux316 3.16.43
linux318 3.18.48 [EOL]
linux41 4.1.39
linux44 4.4.60
linux48 4.8.17 [EOL]
linux49 4.9.21
linux410 4.10.9
linux411 4.11-rc2
linux-RT-LTS 4.4.53_rt66
linux-RT 4.9.20_rt16
Package Updates (Sun Apr 9 01:52:54 CEST 2017)
testing community i686: 395 new and 383 removed package(s)
testing community x86_64: 415 new and 402 removed package(s)
testing core i686: 28 new and 26 removed package(s)
testing core x86_64: 28 new and 26 removed package(s)
testing extra i686: 130 new and 120 removed package(s)
testing extra x86_64: 130 new and 120 removed package(s)
testing multilib x86_64: 1 new and 1 removed package(s)
A detailed list of package changes can be found here.
Re: 2017-04-09 - OpenRC, Thunderbird, Kernels, Deepin, Mate (Testing Update)
Ohne Probleme!
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
Ich habe das leider zu spät gelesen. Thunderbird nun ohne Kalender.  >:D
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
linuxkumpel
Kernel: 5.15 / 6.0
Habe ein Downgrade von Thunderbird durchgeführt und Sprachpaket wieder angepasst. Paar Tage warten und dann wird wohl Lightning auch für die Version 52 vorhanden sein.  :D
