2017-01-27 - Steam, Polkit, Ruby, Calamares (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi Community,
as mentioned in our update feedback of yesterday, we took some time to squash these bugs. The issue with polkit got solved. Also we found a way to fix our steam-client. Teo released Calamares v3.0.1, which includes some needed fixes you can now test with Manjaro 17.0 Beta1 I also just had rebuilt to reflect these made changes. Friends of coding may find the latest Ruby now in our repositories. You also find the latest Upstream updates up till Fri Jan 27 18:42:25 CET 2017. Enjoy and report back as usual ...
Current supported kernels
linux310 3.10.104
linux312 3.12.69
linux316 3.16.39
linux318 3.18.47
linux41 4.1.38
linux44 4.4.45
linux48 4.8.17 [EOL]
linux49 4.9.6
linux410 4.10-rc5
linux-RT-LTS 4.4.39_rt50
linux-RT 4.9.4_rt2
Package Changes
testing community i686: 45 new and 56 removed package(s)
testing community x86_64: 47 new and 57 removed package(s)
testing core i686: 3 new and 4 removed package(s)
testing core x86_64: 3 new and 4 removed package(s)
testing extra i686: 17 new and 17 removed package(s)
testing extra x86_64: 17 new and 17 removed package(s)
testing multilib x86_64: 5 new and 6 removed package(s)
Re: 2017-01-27 - Steam, Polkit, Ruby, Calamares (Testing Update)
Ohne Probleme!
