2016-12-31 - Kernels, LibreOffice, KDE5, VirtualBox, Cinnamon, (Stable Update)
Hatte keine Probleme.
2
50%
1
25%
1
25%
Insgesamt abgegebene Stimmen: 4
Hi community,
only few hours left of the year 2016! During the past few days, most of us spend X-Mas with their families and friends. However some of us still found some time, to add some more packages to our repositories and new features to our tools.
The whole development team wishes you all the best for 2017 and the coming years. Let us finish 2016 with a bang, as the best comes always last.
So what changed and got added?
Bernhard pushed out some more Cinnamon packages
I had the pleasure to update Budgie and some of our kernels
David is working on our new theme Breath (aka Maia2)
Hugo joined our team and designs our new welcome screen, which is now translatable
We added Plasma 5.8.5, KDE apps 16.12 and KDE Framework 5.29
Almost all Kodi addons got updated
LibreOffice is now at 5.2.4
Wine got updated to 2.0rc3
Virtualbox got updated to 5.1.12
Additonally we updated some kernels, haskell and some python packages
As usual report your findings and enjoy the last hours of the year 2016 with friends and family. Detailed package changes can be viewed here.
kind regards,
Philip and the Manjaro Development Team
Current supported kernels
linux310 3.10.104
linux312 3.12.69
linux316 3.16.39
linux318 3.18.46
linux41 4.1.37
linux44 4.4.39
linux48 4.8.15
linux49 4.9.0
linux-RT-LTS 4.4.38_rt49
linux-RT 4.8.14_rt9
Package changes (Thu Dec 29 09:02:56 CET 2016)
stable community i686: 601 new and 564 removed package(s)
stable community x86_64: 604 new and 567 removed package(s)
stable core i686: 18 new and 18 removed package(s)
stable core x86_64: 18 new and 18 removed package(s)
stable extra i686: 773 new and 772 removed package(s)
stable extra x86_64: 774 new and 773 removed package(s)
stable multilib x86_64: 14 new and 10 removed package(s)
Update instruction
FOR SYSTEMD USERS HAVING STILL v231-1 INSTALLED, IT IS RECOMMENDED TO USE PACMAN, AS X-SESSION MIGHT GET LOST DUE THIS UPDATE. THEREFORE WE SUGGEST TO FOLLOW OUR UPDATE RECOMMENDATION . YOU CAN TRY IF FOLLOWING CMD MIGHT CRASH YOUR SYSTEM: sudo systemctl --system daemon-reexec
Check if your mirror has synced , then do the following steps to have a smooth update:
sudo pacman -Sy
sudo pacman -S archlinux-keyring
sudo pacman -Su
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
KDE users should default to Maia theme:
ufw
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
We support now several different steam-clients:
steam-manjaro: is our definition how steam should work on Manjaro.
steam-native: is our definition how steam should be used with our native libraries
steam: is the upstream client by Archlinux
steam-native-runtime: is the addon by upstream Archlinux to use native libraries
The clients by Manjaro are better tested and prefered for Manjaro Linux. However the upstream versions might also work for you.
Reference: Archlinux wiki
Re: 2016-12-31 - Kernels, LibreOffice, KDE5, VirtualBox, Cinnamon, (Stable Update)
Ohne Probleme!
System:  Host: dirk-pc Kernel: 4.9.0-1-MANJARO x86_64 (64 bit)
                Desktop: Xfce 4.12.3 Distro: Manjaro Linux
Prinz
Beitrag von Prinz »
Leider geht seitdem die G13 (siehe Link http://www.manjaro-forum.de/index.php/t ... ml#msg1429) nicht mehr!
Fehlermeldung:
Could not find an uinput device
Kernel driver detached
Found 1 G13s
enrico_zh
Beitrag von enrico_zh »
Nach dem Update hatte ich wieder das Problem, dass sich die Ordner von Thunar mit langer Verzögerung öffneten. Ich habe Thunar in "Automatisch gestartete Anwendungen" aktiviert, wie mir Lumi empfohlen hat (http://www.manjaro-forum.de/index.php/topic,590.msg3831.html#msg3831). Das Problem ist behoben, die Ordner öffnen sich sofort.
Ich wünsche ein GNJ
Manjaro, MX16, LMDE, YACY, Diaspora
Prinz
Beitrag von Prinz »
Fehler gefunden!!!
Die G13 wird nicht in /dev/input gelistet.
tree /dev/input
/dev/input
├── by-id
│   ├── usb-046d_G15_Gaming_Keyboard-event-if01 -> ../event11
│   ├── usb-046d_G15_Gaming_Keyboard-event-kbd -> ../event10
│   ├── usb-Creative_Technology_Ltd._SB_Tactic3D_Rage_Wireless-event-if03 -> ../event12
│   ├── usb-Logitech_G700_Laser_Mouse_F3FFE3CE0035-event-mouse -> ../event2
│   ├── usb-Logitech_G700_Laser_Mouse_F3FFE3CE0035-if01-event-kbd -> ../event5
│   ├── usb-Logitech_G700_Laser_Mouse_F3FFE3CE0035-mouse -> ../mouse0
│   ├── usb-Tablet_PTZ-430-event-mouse -> ../event4
│   └── usb-Tablet_PTZ-430-mouse -> ../mouse1
