We have now Systemd v232, updated Firefox and Thunderbird, renewed most of our
edition settings, updated our python-stack, bumped most of our kernels and
released the latest Mesa point-release. Package changes can be found here.
Upstream packages are up till: Sat Dec 3 10:37:27 CET 2016
Report back your findings as usual ...
Update instruction
FOR SYSTEMD USERS HAVING STILL v231-1 INSTALLED, IT IS RECOMMENDED TO USE PACMAN, AS X-SESSION MIGHT GET LOST DUE THIS UPDATE. THEREFORE WE SUGGEST TO FOLLOW OUR UPDATE RECOMMENDATION . YOU CAN TRY IF FOLLOWING CMD MIGHT CRASH YOUR SYSTEM: sudo systemctl --system daemon-reexec
Check if your mirror has synced , then do the following steps to have a smooth update:
sudo pacman -Sy
sudo pacman -S archlinux-keyring
sudo pacman -SuTroubleshoots
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
We support now several different steam-clients:
steam-manjaro: is our definition how steam should work on Manjaro.
steam-native: is our definition how steam should be used with our native libraries
steam: is the upstream client by Archlinux
steam-native-runtime: is the addon by upstream Archlinux to use native libraries
The clients by Manjaro are better tested and prefered for Manjaro Linux. However the upstream versions might also work for you.
Reference: Archlinux wiki
Current supported kernels
linux310 3.10.104
linux312 3.12.68
linux316 3.16.39
linux318 3.18.45
linux41 4.1.36
linux44 4.4.36
linux47 4.7.10 [EOL]
linux48 4.8.12
linux49 4.9rc7
linux-RT-LTS 4.4.32_rt43
linux-RT 4.8.6_rt5
Package Changes
stable community i686: 581 new and 571 removed package(s)
stable community x86_64: 581 new and 571 removed package(s)
stable core i686: 35 new and 31 removed package(s)
stable core x86_64: 35 new and 31 removed package(s)
stable extra i686: 451 new and 453 removed package(s)
stable extra x86_64: 451 new and 453 removed package(s)
stable multilib x86_64: 27 new and 23 removed package(s)
