besides Python2 updates and Deepin fixes we updated bluez and firefox to the latest release. Firefox comes with new features like multiprocess architecture, updated password manager and hello removed. Also the Vertex-Maia theme issue we had with firefox seem to be solved by now and the menu gets displayed as normal.
Some of our kernels (3.18.42, 4.1.33, 4.4.21_rt30, 4.4.22, 4.7.5, 4.8-rc8) received some updated point releases and MATE 1.16 plus the new LxQT 0.11 got released.
What’s new in LxQT 0.11
Under Openbox an LXQt specific configuration file ~/.config/openbox/lxqt-rc.xml is used from now on.
The taskbar of LXQt, is now behaving well on multi-monitor systems
The main menu comes with a search feature.
A desktop entry file and can as such be dragged into an instance of plugin-quicklaunch
The release is introducing pavucontrol-Qt, the Qt port of PulseAudio’s mixer pavucontrol
What’s new in MATE 1.16
[img width=600 height=375]https://s22.postimg.org/87bib5rrl/screenshot.jpg[/img]
The release is focused on improving GTK3+ compatibility, migrating components to newer libraries, fixing bugs and code hygiene. The headline changes in MATE Desktop 1.16 are:
Improved GTK3+ support across the entire MATE Desktop.
Application and theme support for GTK+ 3.22.
More applications build against GTK3+ only:
Engrampa
MATE Notification Daemon
MATE PolKit
MATE Session Manager
MATE Terminal
Some applications have been decoupled from libmate-desktop:
Engrampa
MATE Applets
MATE Netbook
MATE Power Manager
MATE TerminalPluma
Work has started to port applications to GApplcation:
Engrampa
MATE Applets
MATE Netbook
MATE User Share
Many bugs and deprecations are fixed.
Translations are updated.
Therefore we recommend to use the GTK3 version of MATE from now on ...
Archlinux upstream fixes are now from: Sun Sep 27 09:55 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Detailed package changes can be viewed here3.
Kind regards,
Troubleshoots
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.22
Linux46 4.6.7 [EOL]
Linux47 4.7.5
Linux47 4.8-rc8
Linux-RT-LTS 4.4.21_rt30
Linux-RT 4.6.7_rt13
Package Changes
community i686: 337 new and 353 removed package(s)
community x86_64: 358 new and 375 removed package(s)
core i686: 15 new and 14 removed package(s)
core x86_64: 15 new and 14 removed package(s)
extra i686: 213 new and 213 removed package(s)
extra x86_64: 213 new and 213 removed package(s)
multilib x86_64: 8 new and 6 removed package(s)
