Manjaro Update 2016-01-05 (stable)
[html]We are happy to announce our second update for Manjaro 15.12 (Capella)!
Packages of the new major version of PHP have been released into all our repositories. Besides the new PHP 7 features there are the following packaging changes. In general the package configuration is now closer to what was intended by the PHP project. Also refer to the PHP 7 migration guide for upstream improvements.
Removed packages
php-pear
php-mssql
php-ldap: The module is now included in the php package
php-mongo: The new php-mongodb might provide an alternative even though it is not a compatible drop-in replacement
php-xcache: Consider using the included OPcache and optionally APCu for user data cache
graphviz: The PHP bindings had to be removed
New packages
php-apcu-bc: Install and enable this module if the apc_* functions are needed
php-mongodb
Configuration changes
open_basedir is no longer set by default
openssl, phar and posix extensions are now built in
php-fpm does no longer provide a logrotate configuration. Instead syslog/journald is used by default
php-fpm
Themen Author - Administrator
- CPU: Intel® Core™ i7-2630QM
- GPU: Intel UHD Graphics
- Kernel: 5.6
- Has thanked: 208 times
- Been thanked: 152 times
