[Stable Update] 2021-01-19 - Kernels, XFCE, Plasma, PulseAudio, Pipewire, Mesa, Firefox, Thunderbird, KDE Apps
Hatte keine Probleme.
9
75%
2
17%
1
8%
Insgesamt abgegebene Stimmen: 12
Hello community,
Another stable update. It is also our first of 2021! So happy New Years everyone !!!
Most of our Kernels got an update
XFCE got its major 4.16 release 5
Plasma got updated to 5.20.5 4
KDE Apps is at 20.12.1 2
Mesa got updated to 20.3.3 1
More updates to Gnome, KODI-Addons, Gstreamer and KDE-dev
KDE Frameworks 5.78 got released
Thunderbird is now at 78.6.1
Nvidia started a new long-term series with 460xx 1
A new Quarterly Release 1 of AMDVLK
Pamac got another point-release 2
Some of our Themes got updated
Deepin got further updated packages
Firefox got updated to 84.0.1 1
Mass-Rebuild against ICU
Qt4 got removed
A lot of Haskell and Python rebuilds
Other regular upstream updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 4, which we build on a regular basis against kde-git master packages. Also check out our latest Manjaro Ornara 21.0 preview release! KDE 4, XFCE 1 and Gnome 4
Our current supported kernels
linux44 4.4.251
linux49 4.9.251
linux414 4.14.215
linux419 4.19.167
linux54 5.4.89
linux59 5.9.16 [EOL]
linux510 5.10.7
linux511 5.11-rc3
linux54-rt 5.4.84_rt47
linux59-rt 5.9.1_rt19
Packages Changes (Sun Jan 17 10:45:58 CET 2021)
stable community x86_64: 2349 new and 2275 removed package(s)
stable core x86_64: 56 new and 54 removed package(s)
stable extra x86_64: 1044 new and 1190 removed package(s)
stable multilib x86_64: 43 new and 44 removed package(s)
A detailed list of all package changes can be found here 2.
Jean-Paul
CPU: --
GPU: --
Kernel: --
Desktop-Variante: --
GPU Treiber: --
Has thanked: 42 times
Been thanked: 48 times
Re: [Stable Update] 2021-01-19 - Kernels, XFCE, Plasma, PulseAudio, Pipewire, Mesa, Firefox, Thunderbird, KDE Apps
Beitrag von Jean-Paul »
1.) Backup vom System gemacht.
2.) Update eingespielt, 1,4 GB / 372 Pakete.
3.) Neustart war erforderlich (Hinweis).
4.) System läuft, häufig angewandte Anwendungen ebenso.
Mein XFCE Update lief nicht ganz reibungslos ab. Ich musste vorab den Spektrumanalyser Spek wegen nicht zu erfüllenden Abhängigkeiten deinstallieren. Das Update hat mMn auffallend lange gedauert, fast beunruhigend lange :)
Eventuell empfinde ich das aber auch nur so, weil mein Verhältnis zu Manjaro Updates inzwischen schwer gestört ist. ;D
Und -schauen wir mal, wie lange es dauern wird, bis im Manjaro Team jemand bemerkt, das die Spaltenaufteilung vom Anwendungsmenü etwas zu eng geraten ist....
Ich kann darüber bald echt nicht mehr lachen.
Nächster PC, nächstes Problem.
35) OpenSSL SSL_connect: Die Verbindung wurde vom Kommunikationspartner zurückgesetzt in connection to download.qt.io:443
==> FEHLER: Fehler beim Download von https://download.qt.io/archive/qt/4.8/4.8.7/qt-everywhere-opensource-src-4.8.7.tar.gz
    Breche ab...
Fehler beim Erstellen von qt4
Ich dachte, QT4 soll durch das Update entfernt werden.
Has thanked: 67 times
Spek gibt es ja nur als Build Datei im AUR.
Installation bricht ab wegen Abhängigkeit von wxgtk und zu vielen Sicherheits lücken.
So die Meldungen beim Installations Versuch.
Das Update lief diesmal auf meinem Hauptrechner ohne Probleme durch, aber danach fehlte die Orage-Uhr und die Icons vom Sitzungsmenü/Aktionsknöpfe sind geändert.
@djeli: Der Bootloader von Void kann Manjaro nicht starten, du solltes den Bootloader von Manjaro verwenden.
Wiki
Hast du den Empfang von PNs deaktiviert?
Josef
Nutzt hier noch jemand das Notizen xfce4-notes-plugin und kann bestätigen, das der Cursor auf den Notizzetteln seit dem Update nicht mehr sichbar ist?
Allfred
Has thanked: 71 times
Beitrag von Allfred »
Pamac hängt seit 20 Minuten:
https://manjaro.mirrors.lavatech.top/stable/core/x86_64/psmisc-23.3-4-x86_64.pkg.tar.zst: Zeitüberschreitung bei Ein-/Ausgabeoperation des Sockets
https://manjaro.mirrors.lavatech.top/stable/core/x86_64/libmpc-1.2.1-1-x86_64.pkg.tar.zst: Zeitüberschreitung bei Ein-/Ausgabeoperation des Sockets
https://manjaro.mirrors.lavatech.top/stable/core/x86_64/linux-firmware-20210109.r1812.d528862-1-any.pkg.tar.zst: Verbindung ist gescheitert: Zeitüberschreitung bei Ein-/Ausgabeoperation des Sockets
https://manjaro.mirrors.lavatech.top/stable/extra/x86_64/gst-plugins-base-libs-1.18.3-1-x86_64.pkg.tar.zst: Zeitüberschreitung bei Ein-/Ausgabeoperation des Sockets
zuvor wurden 1GB herunter geschaufelt.
argh ... jetzt geht weiter. O:-)
Edit: läuft !!
Allfred hat geschrieben: Dienstag 19. Januar 2021, 18:02 Pamac hängt seit 20 Minuten:
Vielleicht solltest du die Mirrorlist aktualisieren
sudo pacman-mirrors -f5 && sudo pacman -Syu
Problemlos erledigt. :)
Nach dem Neustart ist alles so wie es sein soll.
xfce4-notes-plugin
Ist bei mir sichtbar
nijila
CPU: AMD Ryzen 5 PRO 4650G
Kernel: stable, actual
GPU Treiber: amdgpu
Has thanked: 16 times
Been thanked: 8 times
Beitrag von nijila »
Guten Abend an alle,
leider hat er mir beim Update ein Gutenberg.xyz...keine Ahnung + den Cups Treiber, den ich ausdrücklich deinstalliert hatte, angedreht. Zusammen mit qt4, dass er nicht installieren konnte.
Daher habe ich den cups&Gutenberg Mist entfernt und neu gestartet. Trotzdem will er weiterhin qt4 installieren.
Ich dachte, ich bin "clever" und deeinstalliere einfach qt4 aber stattdessen will er qt4 + cups dann zwangsinstallieren, siehe Screenshot. Sorry, ich verstehe das nicht :(
Allfred
qt4 Problem
Beim Update auf Manjaror 20.2 fiel auch mein pybitmessage unsupportet weg.
Nach dessen Deinstallation
:: pyqt4-common is unmaintained!
:: python-sip-pyqt4 is unmaintained!
:: python2-sip-pyqt4 is unmaintained!
Auch bei mir wird ein Update qt4: 4.8.7-29.1 ==> 4.8.7-32 versucht und stets abgebrochen:
==> Erstelle Paket: qt4 4.8.7-32 (Mi 20 Jan 2021 09:01:35 CET)
==> Empfange Quellen...
  -> Lade qt-everywhere-opensource-src-4.8.7.tar.gz herunter...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:01:37 --:--:--     0
curl: (35) OpenSSL SSL_connect: Die Verbindung wurde vom Kommunikationspartner zurückgesetzt in connection to download.qt.io:443
    Breche ab...
:: Unable to build qt4 - makepkg exited with code: 1
Allfred hat geschrieben: Mittwoch 20. Januar 2021, 10:27 ....Auch bei mir wird ein Update qt4: 4.8.7-29.1 ==> 4.8.7-32 versucht und stets abgebrochen:
Lese dir bitte den von @Blueriver in Post#1 zitierten Quellenauszug zum Stable Update durch.
Dort steht doch zu lesen, das qt4 fortan nicht mehr unterstützt wird.
Ich vermute, dass bei dir (euch) Anwendungen aus dem AUR installiert sind bzw. waren, die auf qt4 basieren und eventuell ein qt4 Zusatzpaket aus dem AUR nachgezogen haben. Suche im Paketmanager mal mit >Durchstöbern< nach dem Suchbegriff qt4. Wenn sich damit etwas findet, stammt es sicherlich aus dem AUR - und muss weg. Danach dürften auch keine weiteren Versuche seitens des Paketmanagers mehr stattfinden, qt4 weiterhin installieren zu wollen.
Thatsme
CPU: verschiedene
GPU: verschiedene
Kernel: LTS 5.4.105-1
Has thanked: 77 times
Been thanked: 23 times
Beitrag von Thatsme »
Na toll. qt4 brauche ich für KeePassX.
Nächste Woche kommt mein neuer Laptop und mit dem wohl auch eine andere Distri, wenn das mit Manjaro so weiter geht :(
