2019-01-23 - Kernels, Mesa, Browsers, Nvidia, Deepin, VirtualBox (Stable Update)
Gesperrt
Hatte keine Probleme.
5
71%
2
29%
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 7
Important notice
Please use pamac upgrade --enable-downgrade or sudo pacman -Syyuu for this update, to avoid issues! Please also read the troubleshoot section before you update.
Hi community,
Welcome to our fourth stable update of 2019. With this we added a lot of new packages into the mix. So what do we have with this one?
most Kernels got updated. Note that linux44 is currently frozen, as some proprietary drivers don’t build with 4.4.168+. We also removed linux417 and linux418. If you still use these series, please move on to linux419 series and uninstall them, as we won’t compile any extramodules for them from now on.
some updates to Cinnamon and Deepin
rebuilds against new readline and libidn2, therefore please keep close attention to your upgrade and report any issues on those matters
KDE Framework is now at 5.54.0
Mesa is now at 18.3.2
Palemoon is now at 28.3.1
Firefox is now at its eleventh beta release of v65 series
Virtualbox got its first stable point-release of v6.0 series
Nvidia got updated to 415.27
the regular python and haskell updates
FOSDEM19
Some of our core developers will join PINE64 Inc. at FOSDEM19 in Brussels. We will establish an even more closer relationship with this ARM based company. Also we are looking forward to see your reactions on the big announcement PINE64 Inc. will do at FOSDEM19. Stay tuned for any upcoming news.
Partnership with FCS Linux Aarhus
We are happy to announce a new partnership with FCS Linux Aarhus owned by @fhdk. This enables us to offer you Laptops with Manjaro pre-installed and Manjaro Stickers you can use on your own hardware or gift them to a friend. For each sale FCS will donate a percentage to the Manjaro project.
Manjaro v18.0.2 released!
It took us almost two months of development to update Manjaro Illyria. It comes with refreshed packages and updated tools. You may want to download our XFCE Edition with the latest 4.13 packages, aswell as our most recent styling efforts. Our KDE fans may try our KDE Edition with the latest KDE v5.14 instead. And our GNOME fans may try our Gnome Edition with the latest GNOME v3.30.
Current supported Kernels
linux316 3.16.62
linux318 3.18.132 [EOL]
linux44 4.4.167 [FZN]
linux49 4.9.151
linux414 4.14.94
linux419 4.19.16
linux420 4.20.3
linux414-rt 4.14.93_rt53
linux416-rt 4.16.18_rt11
linux418-rt 4.18.16_rt9
A detailed list of all changes made can be found here
Re: 2019-01-23 - Kernels, Mesa, Browsers, Nvidia, Deepin, VirtualBox (Stable Update)
Bei mir ist alles bestens. :)
XFCE und LXQT, Kernel 4.20.
Benutzer 468 gelöscht
Beitrag von Benutzer 468 gelöscht »
@ skill Anfänger eben
mit einem blauen Auge davongekommen.
Habe auch wie gewohnt Upgraden wollen.
Dann Fehlermeldungen bekommen,
Sofort mein snapshot mit Timeshift wiederhergestellt.
Nach Neustart,
Nun unser Forum gelesen.
alles gut hier
Das ausgeführt und gut war und ist.
Off-Topic
Ich brauche keine 7 USB Livesticks
viele Grüße
Benutzer 841 gelöscht
Beitrag von Benutzer 841 gelöscht »
ich sichere mein Manjaro-System mit Timeshift auf meinem von BIOS her kastrierten Notebook. Keine Passphrase !!! Dort wird aber der Kernel 4.14xx LTS benutz (4.19xx geht bislang nicht, black..), außerdem onboard GraKa. Daß heißt das System muss sich nur mit Systemd auseinandersetzen. Bisher gemeistert, Timeshift nicht gebraucht, keine Erfahrung damit.
Auf dem PC w a r (Upgrade-Befehl nämlich von mir auch falsch angg.) die Manjaro-Installation mit Passphrase verschlüsselt. Timeshift nicht benutzt, es hätte doch nicht mit LUKS funktioniert, habe ich längst irgendwo gelesen. Deshalb wurde Install-USB ins Spiel gebracht, Geht schnell.
War dein System mit LUKS verschlüsselt oder nicht, wenn ja, wie hat es sich mit Timeshift verhalten, geht es doch??
MfG ragnar
Hallo @ragnar
nein,
schau mal hier drunter
Timeshift --deine Fragen weiter nach unten srollen
und,
Install Manjaro with LUKS and LVM with encrypted / boot
viele Grüße :)
Hi @ BillGehts,
vielen Dank für deine Mühe, nett von dir!!! Ich werde es zwar ohne Probleme immer hin kriegen, aber es gab in Vergangenheit Diskussionen darüber, wie es unter Passphrase abgeht, dass es nicht geht usw.
Dann geht es noch darüber, was diejenigen sagen, die es ohne USB Live mal durchziehen, wie lange es dauert und wie viele Stolpersteine sie dabei überwinden müssen. Das hier ist nämlich nicht nur für Computerfreeks.
Klasse!!! Tschüß
ragnar
@ mein Tipp an Alle :)
Vor einem Update vielleicht immer dies hier drunter lesen,
nicht auf meinem Mist gewachsen.
Das kam von gosia ( auch in einem anderem Forum ),
vor jedem Update mal lesen
Off-Topic
dann klappt es auch ohne 4 bis 5 Live sticks
viele Grüße :)
Lupus
CPU: Intel
GPU: Intel
Desktop-Variante: Manjaro 18 xfce
GPU Treiber: Intel
Has thanked: 30 times
Been thanked: 29 times
Beitrag von Lupus »
@BillGehts,
AK-Das-japanische-Ultimatum-Gib-her-dein-Papier-Feldgrauer-auf-Plumpsklo-Propaganda-1-Weltkrieg.jpg
AK-Das-japanische-Ultimatum-Gib-her-dein-Papier-Feldgrauer-auf-Plumpsklo-Propaganda-1-Weltkrieg.jpg (94 KiB) 6292 mal betrachtet
@Lupus
kann es sein das Du den Plauder von LMU oder Linuxmintclub vermisst ?
vG :)
Gesperrt
