habe versucht auf dem Brenner des Notebooks Manjaoro zu brennen.
Es entstehen Errors
- mit K3B und mit
- Brasero
anbei der Brasero-Errorlog: Brennvorgang bricht immer ab
Checking session consistency (brasero_burn_check_session_consistency brasero-burn.c:1739)
BraseroBurnURI called brasero_job_get_action
BraseroBurnURI called brasero_job_set_output_size_for_current_track
BraseroBurnURI stopping
BraseroBurnURI called brasero_job_get_session_output_size
BraseroBurnURI output set (IMAGE) image = /tmp/brasero_tmp_GTVXPZ.bin toc = none
BraseroBurnURI called brasero_job_get_current_track
BraseroBurnURI no burn:// URI found
BraseroLocalTrack called brasero_job_get_action
BraseroLocalTrack called brasero_job_set_output_size_for_current_track
BraseroLocalTrack stopping
BraseroLocalTrack called brasero_job_get_session_output_size
BraseroLocalTrack output set (IMAGE) image = /tmp/brasero_tmp_4OVXPZ.bin toc = none
BraseroLocalTrack called brasero_job_get_current_track
BraseroLocalTrack no remote URIs
BraseroChecksumImage called brasero_job_get_current_track
BraseroChecksumImage called brasero_job_get_action
BraseroChecksumImage called brasero_job_get_flags
BraseroChecksumImage called brasero_job_get_fd_in
BraseroChecksumImage called brasero_job_set_output_size_for_current_track
BraseroChecksumImage stopping
BraseroChecksumImage called brasero_job_get_session_output_size
BraseroChecksumImage output set (IMAGE) image = /tmp/brasero_tmp_SNVXPZ.bin toc = none
BraseroChecksumImage called brasero_job_get_input_type
BraseroChecksumImage called brasero_job_set_current_action
BraseroChecksumImage Starting checksuming file /home/martin/Downloads/manjaro-kde-17.1.12-stable-x86_64.iso (size = 2159738880)
BraseroChecksumImage called brasero_job_get_fd_out
BraseroChecksumImage Setting new checksum (type = 2) 9ed9ebc9512aa310ebe3d384d0fc1e70 ((null) before)
BraseroChecksumImage Finished track successfully
BraseroLibburn called brasero_job_get_action
BraseroLibburn unsupported operation
BraseroLibburn deactivating
BraseroLibburn called brasero_job_get_device
BraseroLibburn Drive (/dev/sr0) init result = 1
BraseroLibburn called brasero_job_get_flags
BraseroLibburn called brasero_job_get_media
BraseroLibburn called brasero_job_get_fd_in
BraseroLibburn called brasero_job_get_tracks
BraseroLibburn Setting multi 0
BraseroLibburn Setting burnproof 1
BraseroLibburn Setting dummy 0
BraseroLibburn called brasero_job_get_session_output_size
BraseroLibburn called brasero_job_set_current_action
BraseroLibburn burn_drive_convert_fs_adr( /dev/sr0 )
BraseroLibburn Writing
BraseroLibburn called brasero_job_set_dangerous
BraseroLibburn burn_drive_is_enumerable_adr( /dev/sr0 ) is true
BraseroLibburn Async START UNIT succeeded after 0.1 seconds
BraseroLibburn mmc_set_streaming: end_lba=2297887 , r=11080000 , w=11080
BraseroLibburn Allocating buffer via mmap()
BraseroLibburn dvd/bd Profile= 11h , obs= 32768 , obs_pad= 1
BraseroLibburn DVD pre-track 01 : get_nwa(0), ret= 1 , d->nwa= 0
freue mich von Euch zu hoeren.
