2018-02-22 - MHWD, NVIDIA, Hybrid Graphic Setup (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
this is more or less a fix-up package since our last testing update we did on the 21th
We addressed the issue with nvidiafb and linux415+ series
We upgraded mhwd to v0.6.2 and simplified opensource driver installation for nouveau and amdgpu
We simplified installations on hybrid graphic card setups
We added regular upstream updates like Haskell and Python
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
linux316 3.16.54
linux318 3.18.95 [EOL]
linux41 4.1.49
linux44 4.4.116
linux49 4.9.82
linux414 4.14.20
linux415 4.15.4
linux416 4.16-rc1
linux-RT-LTS 4.14.18_rt15
linux-RT 4.14.18_rt15
Package Updates (Thu Feb 22 07:31:33 CET 2018)
testing community x86_64: 69 new and 67 removed package(s)
testing core x86_64: 2 new and 2 removed package(s)
testing extra x86_64: 6 new and 7 removed package(s)
Re: 2018-02-22 - MHWD, NVIDIA, Hybrid Graphic Setup (Testing Update)
Das Update von 4 Paketen war erfolgreich.
:D
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
Alle 5 Pakete ohne Probleme.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
