2018-02-17 - Kernels, KDE, MATE, Firefox, LibreOffice, Mesa, (Stable Update)
Hatte keine Probleme.
4
80%
1
20%
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 5
Hi community,
it took us a while to prepare this update-pack. Mostly it is due my busy work life at the moment. However managed to squeze the best new open source software for you into this one. For all newcomers to Manjaro, please install Manjaro from our fresh v17.1.5 install ISOs.
Plasma got updated to v5.12.1 LTS
Updated KDE Framework to v5.43
Added KDE Apps v17.12.2
We updated most of our kernels and rebuild all against the new GCC v7.3.0 release
Ryzen CPUs should now be fully protected when AGESA v1.1.0.1 or higher got applied to your BIOS (also disable PSP)
Latest Systemd added
Latest Browsers
Lates Nvidia Drivers
Fixed some issue with Bluetooth headsets in bluez
Had some Haskell and Python updates/rebuilds
LibreOffice updated to v5.4.5 and v6.0.1
Fixed issue with WLAN drivers in our v4.15 kernel series
Updated MATE to v1.20
Worked again on our Adapta theme
Plus the latest upstream updates as usual
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
linux316 3.16.54
linux318 3.18.94 [EOL]
linux41 4.1.49
linux44 4.4.115
linux49 4.9.81
linux414 4.14.19
linux415 4.15.3
linux-RT-LTS 4.14.18_rt15
linux-RT 4.14.18_rt15
Package Updates (Thu Feb 15 05:31:34 CET 2018)
stable community x86_64: 1020 new and 943 removed package(s)
stable core x86_64: 44 new and 45 removed package(s)
stable extra x86_64: 991 new and 1037 removed package(s)
stable multilib x86_64: 27 new and 27 removed package(s)
A detailed list of all package changes can be found here.
Re: 2018-02-17 - Kernels, KDE, MATE, Firefox, LibreOffice, Mesa, (Stable Update)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.15.3-2-MANJARO x86_64 bits: 64
           Desktop: Xfce 4.12.4 Distro: Manjaro Linux
System:    Host: asus-pc Kernel: 4.14.19-1-MANJARO x86_64 bits: 64
           Desktop: LXQt Distro: Manjaro Linux
Fanaro346
Beitrag von Fanaro346 »
Das Update an sich lief ohne Probleme durch.
Da ich das System über das Terminal updaten wollte, wählte ich .
Es erschien dann die Frage "attica-qt5 durch extra/attica ersetzen? [J/n]". Da ich nicht wusste, was das bedeutet, habe ich abgebrochen und über Octopi die Updates installiert.
Ein Problem gab es:
Allerdings kann ich seit dem mein System nicht mehr durch Drücken des Ein/Aus-Schalters in den Standby versetzen. Es tut sich nichts mehr. (KDE Plasma: Systemeinstellungen -> Energieverwaltung -> Ernegiesparen -> Knopf-Ereingnisbehandlung.
Ich bin dann zu Kurzbefehle -> Globale Kurzbefehle und habe dort unter Energieverwaltung bei Standby-Modus den Ausschalten-Knopf eingestellt. Nun geht es wieder.
Allerdings ist das ja so nicht vorgesehen, denn die entsprechende Einstellung funktioniert nicht mehr.
Ansonsten alles gut. Bis auf andere Versionsnummern der Programme keine Veränderungen festgestellt :-)
EDIT: Scheint doch ein größeres Problem zu sein, denn Strg+Alt+Ent zum Anzeigen der Ausschalten-Optionen geht auch nicht mehr.
Zuletzt geändert von Fanaro346 am Samstag 17. Februar 2018, 23:37, insgesamt 1-mal geändert.
Quinix
Beitrag von Quinix »
das hilft dir jetzt sicher leider nicht, aber ich hatte auch diese frage bzgl attica. danach sofort das update, bevor es los ging, abgebrochen und im "hauptforum" diesbezüglich eine frage abgesetzt. dauerte nicht all zu lange und die antwort kam. diese pakete sollten auf jeden fall ersetzt werden weil eben neuer usw.  übrigens folgten der frage (ersetzen)  noch mindestens 10 ähnliche. hab es dann alles durch-gewunken (zum glück), und alles ist fein.
ergo. in den foren sofort fragen wenn man sich nicht sicher ist und geduld haben , bis eine antwort kommt. besser ist das.  ;-)
ebenfalls macht es sinn den beigefügten link "quelle", zu öffnen und dort ein auge drauf zu haben.
dieses attica und der eigentlich dann noch folgende kram ist AFAIK wichtig. da es ein update der QT bibliotheken ist
an deine stelle würde ich dort jetzt nicht wild dran rum basteln.  mal reboot (falls noch nicht nach dem update gemacht), und dann nochmal update abfrage machen, und hoffen daß die diversen pakete erneut angeboten werden.
ich hatte letztens bei so einer update frage ebenfalls  falsch gehandelt, nicht die foren beachtet und einfach alles ignoriert.
fazit war daß mein damaliges und lange gut laufendes system (über 3 jahre ohne jegliche probs) , dann die grätsche machte.
aber anstatt mal abzuwarten (2 tage später kam ein update fix der das prob behoben hätte) ) und diverse möglichkeiten auszuschöpfen, vorschnell eine neu installation gemacht, obwohl einiges noch ging.  mangels geduld usw.  war es ein hoher preis IMHO, für mich.
passiert mir nie wieder.  ;)
[quote="Fanaro346"]
Ein Problem gab es:
Fanaro346
Ich habe dann das Update ja über Octopi machen lassen. Der hat mir die Entscheidung abgenommen: attica-qt5 ist nicht mehr installiert, dafür attica.
Ohne Probleme...... ???
