2018-02-08 - Kernels, Browsers, Plasma, GCC, Nvidia, Systemd (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
it took us a while to prepare this update-pack. Mostly it is due my busy work life at the moment. However managed to squeze the best new open source software for you into this one:
Plasma got updated to v5.12 LTS
We updated most of our kernels and rebuild some against the new GCC
Ryzen CPUs should now be fully protected when AGESA v1.1.0.1 or higher got applied to your BIOS (also disable PSP)
Latest Systemd added
Latest Browsers
Lates Nvidia Drivers
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
linux316 3.16.53
linux318 3.18.94 [EOL]
linux41 4.1.48
linux44 4.4.116
linux49 4.9.89
linux414 4.14.18
linux415 4.15.2
linux-RT-LTS 4.14.15_rt13
linux-RT 4.14.15_rt13
Package Updates (Thu Feb 8 14:14:01 CET 2018)
testing community x86_64: 584 new and 533 removed package(s)
testing core x86_64: 33 new and 34 removed package(s)
testing extra x86_64: 339 new and 367 removed package(s)
testing multilib x86_64: 11 new and 11 removed package(s)
A detailed list of changes can be found here.
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Re: 2018-02-08 - Kernels, Browsers, Plasma, GCC, Nvidia, Systemd (Testing Update)
Beitrag von linuxkumpel »
Es lief wie immer. Reboot auch alles o.k.  ??? System immer schön sauber halten und dann klappt es auch mit den Updates.  :D
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Bei mir ist auch alles bestens.
