2018-01-05 - Kernels, KPTI, Plasma, Calamares, TLP (Stable Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hi community,
we hope you all had a great start into 2018! We are happy to present the first stable update for 2018. Thx to your feedback we could fix some issue within tlp, updated Plasma to v5.11.5, worked on Calamares and fixed some regressions in update-notifie
Additionally we worked close with upstream to include the kernel page-table-isolation into most of our LTS kernels. More about our effort and all the needed information about the new security risk can be found here
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
linux316 3.16.52
linux318 3.18.91 [EOL]
linux41 4.1.48
linux44 4.4.109
linux49 4.9.74
linux412 4.12.14 [EOL]
linux413 4.13.16 [EOL]
linux414 4.14.11
linux415 4.15-rc6
linux-RT-LTS 4.9.68_rt60
linux-RT 4.11.12_rt16
Package Updates (Thu Jan 4 13:28:53 CET 2018)
stable community x86_64: 222 new and 209 removed package(s)
stable core x86_64: 19 new and 18 removed package(s)
stable extra x86_64: 163 new and 168 removed package(s)
stable multilib x86_64: 3 new and 4 removed package(s)
Re: 2018-01-05 - Kernels, KPTI, Plasma, Calamares, TLP (Stable Update)
Ohne Probleme!
Been thanked: 153 times
Alles bestens auch bei mir.  ???
