inxi -Faz
System:
Kernel: 5.15.160-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=0f4b49ec-1a0a-4ffc-b87a-76de1c505340 rw quiet apparmor=1
security=apparmor udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker,xfce4-screensaver vt: 7 dm: LightDM
v: 1.32.0 Distro: Manjaro base: Arch Linux
Machine:
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME B550M-A v: Rev X.0x
serial: <superuser required> part-nu: SKU uuid: <superuser required>
UEFI: American Megatrends v: 3607 date: 03/22/2024
CPU:
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000F
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4011 high: 4594 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3672 2: 3672
3: 4594 4: 4589 5: 3668 6: 3670 7: 3668 8: 3656 9: 4567 10: 4074 11: 4582
12: 4592 13: 3673 14: 3913 15: 3673 16: 3916 bogomips: 121427
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: retbleed status: Not affected
Type: spec_rstack_overflow mitigation: safe RET
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW;
STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
empty: DP-1,DVI-D-1 bus-ID: 0b:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 29.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: TV-monitor serial: <filter>
built: 2019 res: 3840x2160 hz: 60 dpi: 138 gamma: 1.2
size: 708x398mm (27.87x15.67") diag: 1321mm (52") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Audio:
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 0b:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 0b:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k5.15.160-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsactl,alsamixer,amixer
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Network:
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: mld,NetworkManager
Drives:
Local Storage: total: 7.77 TiB used: 7.61 TiB (98.0%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: MZVL2512HCJQ-00B00 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: GXA7601Q temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Utania model: OOS8000G size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 5425 serial: <filter> fw-rev: OOS1
ID-3: /dev/sdb maj-min: 8:16 vendor: Intenso model: Rainbow Line
size: 29.77 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 1.00
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Partition:
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 355.64 GiB (76.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Swap:
Sensors:
System Temperatures: cpu: 46.4 C mobo: N/A gpu: amdgpu temp: 31.0 C
Fan Speeds (rpm): N/A
Info:
Memory: total: 32 GiB note: est. available: 30.65 GiB used: 3.38 GiB (11.0%)
Processes: 384 Power: uptime: 1m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.25 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1766 libs: 437 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.35
alsactl init
aber mit dem BefehlTuroy hat geschrieben: Dienstag 25. Juni 2024, 20:36
"jetzt" ging's natürlich wieder OHNE den Umweg über's Internet-Radio. Morgen passiert's bestimmt wieder mal, dann teste ich es !
alsactl init
Found hardware: "HDA-Intel" "ATI R6xx HDMI" "HDA:1002aa01,00aa0100,00100700" "0x1043" "0x8809"
Hardware is initialized using a generic method
Found hardware: "HDA-Intel" "Realtek ALC897" "HDA:10ec0897,104387fb,00100402" "0x1043" "0x87fb"
